Old 03-20-2011, 02:29 PM   #16
I'm Your Huckleberry
furnace does not stay on
Looking at your picture again I now notice that those lines and the black box thing is mounted to the blower wheel as by the word "rotation" on the housing. Did you open up that lower door and find those in side there?
I honestly do not know what that is from sitting here, sorry.
Doc Holliday is offline   Reply With Quote
Old 03-20-2011, 03:22 PM   #17
HVAC / Plumbing
that black box is the condensate drain for the furnace. the a/c coil should be on top of the furnace. If the fan/limit is rotating around (even with the fan on) and tripping the limit you have air flow issues
kenmac is offline   Reply With Quote
Old 03-20-2011, 03:32 PM   #18
Thanks. I do not have a lot of time with condensing furnaces.
Is the evaporator drain line tying into those lines or is it run seperately?
Old 03-20-2011, 03:45 PM   #19
HVAC / Plumbing
condensate line would be separate
Old 03-20-2011, 04:38 PM   #20
Service tech just left, heat is blowing like crazy in here. lol. By sheer dumb luck the last picture I posted was actually the problem. Apparently the black thing is the trap, and it was clogged. I believe one of the lines came from the secondary heat exchanger to trap? The trap empties into a little pump outside of the furnace where it is pumped to a laundry sink. Anyway he cleaned the trap out and it took off from there. Thanks for all of your help.
Nick
ndove is offline   Reply With Quote
Lennox Furnace G27M Series – Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Goodman GMP Furnace won't stay lit. JoelT HVAC 10 12-16-2012 12:24 PM
Gas Furnace will not stay lit... sobro HVAC 3 10-12-2010 10:22 AM
Dayton Gas Furnace burners wont stay lit Marie1313 HVAC 38 10-08-2009 05:38 PM
Goodman Furnace GMNT100-4b Won't stay on freeslporer HVAC 3 10-30-2008 07:42 PM
