Furnace Does Not Respond To Thermostat Actions - HVAC - DIY Chatroom Home Improvement Forum
Old 09-25-2012, 10:49 AM   #1
Furnace does not respond to Thermostat actions
Hello all,
We had issues with the Furnace/AC unit and technician replaced the Thermostat with newer digital one thinking our issue was the Thermostat. now the Thermostat will not turn on/off the unit. He installed a second one thinking the the first unit was defective but still the same issue.
Any idea what needs to be looked at now? thanks
cyp555 is offline   Reply With Quote
Old 09-25-2012, 11:17 AM   #2
Rewards Points: 582
Originally Posted by cyp555 View Post
Hello all,
comfirm that you have 24 volts to system....check fuse on control board....start there. just courious why is tech not finishing his troubleshooting???
Old 09-25-2012, 11:34 AM   #3
first issue was the condenser motor fan would not always come on when the unit was on so he cleaned the AC lines but that did not fix the problem so he replaced the Thermostat thinkin it was the issue. now he is stomped and does not know where to go from here. Sounds like time for new tech.
Is the control board inside the furnace? thanks
Old 09-25-2012, 11:46 AM   #4
An old Tradesmen
Rewards Points: 7,816
And ask for a refund from that A/C company. or for a tech that knows what he is doing.
The Following User Says Thank You to beenthere For This Useful Post:
ben's plumbing (09-25-2012)
Old 09-25-2012, 06:35 PM   #5
Rewards Points: 582
board is inside furnace.....agree with bt ask for refund... that tech dosen't know hvac service.....its basic troubleshooting....most furnaces almost tell us whats wrong...
Old 09-26-2012, 06:50 AM   #6
biggles's Avatar
cleaned the ac lines...to fix a control problem..time for a refund...remove the stat and jump R to W ..get back with what happens at the furnace..if you have a control modue within that furnace ....led/lights 24Vs no lights no 24Vs....if the stat has a led screen and it is lit up 24Vs is present....does the NEW subbase have a C terminal on it?
The Following User Says Thank You to biggles For This Useful Post:
ben's plumbing (09-26-2012)
furnace or thermostat problem? jhack836 HVAC 1 02-11-2012 12:19 PM
oil furnace & programmable thermostat Ted Hanley HVAC 2 01-01-2012 11:40 AM
thermostat to furnace wiring Craig66 Electrical 2 11-03-2011 01:57 PM
manual bypass for furnace thermostat. foxsam HVAC 8 11-07-2008 12:20 PM
One furnace question and one thermostat question lh0628 HVAC 4 10-11-2007 10:17 PM
