Furnace Does Not Like Temps Under About 40... - HVAC - DIY Chatroom Home Improvement Forum
Old 12-04-2011, 11:27 AM   #1
Hello all, I am new to this fourm, I have read a few posts and think I may have an idea of my issue but want to flush it out a bit.
I have an rooftop HVAC gas unit that is about 10 years old. The last two winters (this being the second) the heater works fine and with every expectancy EXCEPT when the temps reach under 40 degrees. I live in Las Vegas, NV so this happens not so frequent, but it happens enough.
I had a HVAC contractor I know (he has done a lot of our buildings at our achitectural office) look at it last November. He replaced a vacummn line and that seemed to work at the time, but then again it was an easy winter.
This year again on our first "cold night" (under 40) the heat didn't turn on, in the morning (with warmer temps) it turned on just fine.
Any suggestions? I can upload some pics when I get a chance to get on the roof. My guesses are:
1. The colder air causes a vacuum lock....
2. The temp range is to much to over come and it cycles off?
3. Bad flame sensor (but this doesn't explain why there are issues only when temp is under 40)
4. The regulator at the gas meter is restricting addition gas flow that may be needed
Ken
Sent from my EVO using DIY Chatroom
thepunk76 is offline   Reply With Quote
Old 12-04-2011, 02:48 PM   #2
HVAC Tech/ Browns Fan
It maybe the fresh air calamizer is stuck open if one is on it
Tator1076 is offline   Reply With Quote
Old 12-04-2011, 04:00 PM   #3
AKA HVACTECHFW
Rewards Points: 1,208
i think you mean economizer....................LOL!!!! Never heard it call a calmizer before!
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 12-04-2011, 04:38 PM   #4
OMG I did spell it wrong lol
Old 12-04-2011, 07:02 PM   #5
That would make a difference and not kick in when its 40 or cooler but not at say 55?
ken Sent from my EVO using DIY Chatroom
Old 12-04-2011, 07:28 PM   #6
Is this something that I can see operating or not operating?
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 05:01 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 06:42 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 01:12 PM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 10:42 PM
