Furnace Does Not Go Off. - HVAC - DIY Chatroom Home Improvement Forum
Old 02-22-2010, 01:06 PM   #1
Furnace does not go off.
I have a new problem with my dual fuel gas furnace. I originally thought it was the defrost because it does it whenever I am leaving for work, or very late at night. Times I am not willing to go and check on it. But last night it stayed stuck after I turned the heat up, on a relatively warm night. I doubt it is the thermostat because it will not turn off unless I turn the unit off or put the thermostat between heat and off, it will still run if it put it in off. I am thinking it is the furnace control board.
H. Phillips is offline   Reply With Quote
Old 02-22-2010, 02:43 PM   #2
An old Tradesmen
Rewards Points: 6,876
If it was the furnace control board. Then turning the switch between heat and off should have no effect.
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Furnace air filtration advice stephen_smith HVAC 7 12-24-2010 02:24 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
