Furnace Cycle Problem - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 12-03-2011, 04:47 PM   #16
Thanks, Yuri,
That's where I went. I found the parts I need pretty inexpensive at Arnold's: http://arnoldservice.com/bryant_carrier_parts.htm, so I just added a limit switch to my order for the 3-wire pilot. I figure I'll install the new parts and see what happens. I guess, if the the cycling continues, I'll be looking for air obstructions.
Thanks,
Dave
dave54 is offline   Reply With Quote
Old 12-18-2011, 09:27 AM   #17
I just wanted to post an update to say "thanks" for all the help and to let everyone know the final outcome. I replaced the 3-wire pilot and the limit switch, but broke the darn connector off the fusible link in the process. I tried soldering the link connector, but once that was done, the link no longer had continuity. After replacing the link, everything worked like a charm.
Again, thanks for all the help!
Dave
Tags
carrier , cycle , furnace
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
Help troubleshooting furnace problem robert_ HVAC 21 02-15-2012 08:04 AM
Help with furnace blower problem Spydey HVAC 6 12-15-2010 08:18 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 06:42 PM
Strange Problem with My Furnace chenjijc HVAC 14 11-04-2009 09:05 PM
