Furnace In Crawl Space Vent Horizontal - HVAC - DIY Chatroom Home Improvement Forum
Old 08-15-2011, 07:21 PM   #1
Furnace in crawl space vent horizontal
I am buying a house and the home inspector stated
"Improperly sloped vent pipe noted. This will allow
products of combustion to escape. This is a safety hazard
needing immediate attention by a licensed heating contractor"
Is an incorrectly sloped vent dangerous?
SharonH1 is offline   Reply With Quote
Old 08-15-2011, 07:51 PM   #2
That is why there's a code dealing with vent slopes. Hot air rises so if the flue is sloped the wrong way then the combustion byproducts,including carbon monoxide, spill into the house. When that happens you get sick because your internal organs are shutting down from lack of oxygen,or you just up and die.
Old 08-15-2011, 09:31 PM   #3
An old Tradesmen
Rewards Points: 6,108
Yes, incorrect slope can let carbon monoxide escape and enter your crawlspace and house.
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Open crawl space to heated basement benjamincall HVAC 1 03-04-2011 08:52 PM
Vent pipe - horizontal? secutanudu Plumbing 3 03-02-2011 07:23 PM
crawl space venting and HE furnace? bcbud3 Remodeling 10 03-09-2010 04:33 PM
Foundation crawl space vent size problem Constant Improvement Building & Construction 15 01-15-2009 06:07 PM
