Old 01-24-2010, 12:33 PM   #1
Furnace Conversion
I am converting my Bryant furnace model 376CAV, from propane back to natural gas. I need the parts to convert the gas valve back to natural gas. The valve is brand new and was converted to burn propane when it was installed this summer. All of the kits go from NG to propane, not the other way. Any ideas would be appreciated. The valve is a White Rodgers 36H32-304.
vland is offline   Reply With Quote
Old 01-24-2010, 01:01 PM   #2
Furnace Conversion
You will need the burner orifices, pilot orifice if equipped with a pilot and the spring kit for the gas valve. Usually the nat. gas parts are saved when it is converted to lp.. Should be able to get some help from a Bryant dealer.
SKIP4661 is offline   Reply With Quote
Old 01-24-2010, 01:17 PM   #3
Furnace Conversion
Thanks, I understand from the tables in my instruction manual, I will need 3 #42 orifices and the gas valve parts. I don't have a pilot so that's not a problem. The parts I need are normally tossed after the conversion is made so they're difficult to find without buying a new valve.
Tags
conversion, gas valve, propane, propane to ng
Lennox Furnace G27M Series – Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 06:42 PM
Furnace air filtration advice stephen_smith HVAC 7 12-24-2010 03:24 AM
Furnace replacement and conversion from propane to NG. crblog HVAC 2 05-22-2009 04:57 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
