Furnace Control Boards - Interchangeable? - HVAC - DIY Chatroom Home Improvement Forum
Old 10-15-2010, 12:09 AM   #1
Rewards Points: 43
Furnace control boards - interchangeable?
A few months ago, I had someone working on my outdoor a/c unit, and he accidentally shorted out the control board in the furnace (it's a Goodman gas furnace GKS91155DX). He replaced the board, and the a/c did end up working, but when I tried to start the heat today, the burners would not stay on for longer than a few seconds before cutting out.
After ruling out the usual culprits (flame sensor, bad ground, etc.), I turned my attention to the control board, and after a little research I came to realize that it was the wrong board! The one in my furnace was PCBBF122, while the one listed in the service manual for my model is PCBBF112.
Does anybody know whether these boards are generally interchangeable? The terminals are mostly the same, except that the "wrong" board has 2 extra terminals -- one for "LO HEAT" and the other for "EAC-H".
Thanks!
bugmenot is offline   Reply With Quote
Old 10-15-2010, 03:27 AM   #2
call the local supplier and make sure. You can even make a google search.
My 2 cents is that if all the plugs in are the same you probably have the right part.
hvaclover is offline   Reply With Quote
Old 10-15-2010, 11:12 AM   #3
Rewards Points: 43
It turns out they're not compatible -- the one I need is for one-stage, and the other one is for two-stage.
Old 10-15-2010, 11:52 AM   #4
Well than I guess all the plug-ins were not the same.
And how did you find out about the board?
Old 12-13-2010, 05:37 AM   #5
goodman furnace control board- for bugmenot
the board that was given you is a 2 stage board but that chould not stop you from using it. The EAC is for elctronic air cleaner connection ( most new boards have it). The fan motor connection for heat should go to stage 1 and shold be red or blue wire from motor. The stage 2 should have the yellow or orange wire connected to it. This will give you a step-up in speed as the heater progresses. The only difference that you are trying to overcome is that a furnace that usually uses this board, comes with a multistage blower motor, but everything else is the same and it should work in your furnace.
macgiver is offline   Reply With Quote
Tags
control board , electronics , furnace , hvac
Furnace air filtration advice stephen_smith HVAC 7 12-24-2010 03:24 AM
Generator and furnace okrite Electrical 11 12-30-2009 10:50 AM
Universal furnace control board Davidj0717 HVAC 1 10-14-2009 06:37 PM
heil gas furnace fan control shooter49 HVAC 1 10-24-2008 02:51 PM
First Furnace Install - Need Some Help Getting Started hartkem HVAC 17 10-11-2008 12:55 PM
