Furnace Connector Rise? - HVAC - DIY Chatroom Home Improvement Forum
Old 12-28-2011, 01:38 PM   #1
Furnace connector rise?
I need to move the vent from my furnace to a new location. It is a The Bryant 396HAD Induced-Combustion, 78%, Gas Furnace. What is the minimum rise needed before the first 45 degree bend. It is in the basement, the only appliance on the type b vent. It needs to rise up - bend 45, run horizontal for about 4 feet, bend again and then go straight up 20 feet through the roof.
The way it is set-up now is no reference as it is a complete "hack" - and it is why I need to change it.
Thank you in advance for any advise
jpiazzo is offline   Reply With Quote
Old 12-28-2011, 04:50 PM   #2
Hvac Pro
yuri's Avatar
Rewards Points: 1,452
No minimum rise that I know of. The main thing is to vent it using B vent from the furnace to the chimney as single wall vent allow the fumes to cool down 2 much and can condense in the venting or chimney.
Old 12-28-2011, 06:36 PM   #3
REP
I have only seen a required height requirement on a vent one time and I think it was on a PVC off a 90% furnace.
YURI is right you want "B" vent from the furnace and it wouldn't hurt anything if you had a 1" rise on that 4' length too.
REP is offline   Reply With Quote
Old 12-28-2011, 07:09 PM   #4
Hvac Pro
yuri's Avatar
Yep. you do need some rise on the horz pipe, 1" at least.
Old 12-28-2011, 07:46 PM   #5
how
Rewards Points: 1,102
Quote
Doesn't this mean that what he calls horizontal is already rising at a 45 degree angle?
how is offline   Reply With Quote
Old 12-28-2011, 08:30 PM   #6
REP
Originally Posted by how View Post
Quote
Quite right and it would be more than an inch which is good.
Old 12-28-2011, 08:32 PM   #7
Hvac Pro
yuri's Avatar
Now my head hurts thinkin about it. Will have to talk to my cousin Jethro about dem der matheematics. 1 gizinta two gizinta.
Old 12-28-2011, 08:44 PM   #8
Rewards Points: 582
set your rise at 1/4" per foot min to 1st 45...then continue with your plan....will work fine..
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 06:01 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 07:42 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 02:12 PM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 11:42 PM
