Furnace Is Condensating? - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 03-05-2012, 09:25 PM   #31
I'm sorry... the smartvalve is what?
Andrew W is offline   Reply With Quote
Old 03-05-2012, 09:25 PM   #32
GC/Master Plumber/Mech
Rewards Points: 560
I;m leaning more to the pilot assy
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 03-05-2012, 09:26 PM   #33
Rewards Points: 560
Gas valve
Old 03-05-2012, 09:34 PM   #34
OK... I was just talking about the coils because a tech said something about the heat is mixing with the cool coils and water going back to the fuhrnance..he cut me a break and didnt charge me... and told me to call the AC guys... (I just had a new AC unit installed last year)... the ac guy came over, I told him what the other tech said... he said i had bad caulking in my bath tub/etc and water is leaking/ resting on the vents... to evaporate into the system. I havent showered in my bathroom in months.. and this is still happening...
Old 03-05-2012, 09:40 PM   #35
Rewards Points: 582
I thougth about that...he said it was cleaned...also thougth about pilot senser on ignitor assy...
Old 03-05-2012, 09:44 PM   #36
I really do want to thank you guys for staying on and trying to help me...i do appreciate it... dont know if you're still on but thanks anyway... I really appreciate it...
Old 03-05-2012, 09:45 PM   #37
Rewards Points: 560
Not so much the pilot assy but the ignitor/sensor. They can cause some funny issues.
Old 03-05-2012, 09:50 PM   #38
Rewards Points: 582
your welcome just frustrating when you can't solve a problem.....I think we need to be there to see other things happening as we watch furnace operate...back to my thougth ..ignitor /senser.....1st .......gas valve 2nd........may need to get a service tech in ...ben
Old 03-05-2012, 10:01 PM   #39
Thanks.. I've had service techs in for a while... quite a few times...I feel like i just waste money... one more question... the heading of the "chimney" came off a while ago and my dad duck taped it back on... could this cause some kind of problem? just thought of this... is there supposed to be a certain amount of room for vent?
Old 03-05-2012, 10:23 PM   #40
Rewards Points: 582
with out really seeing hard to tell ...the pressure switch is suppose to guard against blocked chimney...don't seem like that is causing any trouble.
The Following User Says Thank You to ben's plumbing For This Useful Post:
Andrew W (03-05-2012)
Old 03-05-2012, 10:42 PM   #41
Thanks... Really .. Thanks guys for trying to help me out... I'm going to put everything back together and I dont know... what i'm going to do.. but thanks for trying to help me... I do appreiciate it.
Gas valve
Old 03-05-2012, 10:54 PM   #42
Rewards Points: 154
hum
If the ignitor is glowing red and the gas valve isnt opening then it is probably the gas valve. The only way to know for sure is to be there with a meter when the valve doesnt open to see if its getting a 24V signal. It will also happen when your flue pipe fills with water and your losing pressure from water being sloshed in your inducer assembly. Start by disconnecting the flue pipe to make sure its clear. If it is clear then connec the cap back on correctly and move to the inducer fan housing. Pull off the red hose from the pressure switch and suck on the hose to see if you can get any water from the inducer assembly. If its clear, go buy a cheap voltage meter. When the ignitor is red, have the two leads on the two wire leads on the gas valve. If its showing voltage and the valve isnt opening then it may be the valve. It could also be a frozen gas regulator. We see it all the time.
Patrick Eubanks is offline   Reply With Quote
Old 03-06-2012, 05:21 AM   #43
An old Tradesmen
Rewards Points: 6,112
Chimney cap came off? Check for rust debrie to be in pipe at furnace. may even be inside the inducer.
Moisture in that tube is a sign of low gas pressure, or slight blockage in the vent system.
The Following User Says Thank You to beenthere For This Useful Post:
ben's plumbing (03-06-2012)
Old 03-06-2012, 08:54 AM   #44
Could be a cold chimney too...lotsa of those jobs were installed with a vent kit ..although this may not...cant see the pice of the flue.
I don't think any body asked if it was a brick or b-vent. Chances are there was no liner and the condensation collected in the hose.
hvac5646 is offline   Reply With Quote
Old 03-06-2012, 01:37 PM   #45
how
Rewards Points: 1,070
or if it is a brick chimney is it on an exterior wall or enveloped by the buildings heating envelope. The last time i saw a problem like this on a brick chimney (with a liner) it was just because the chimney clean out was off, chilling the liner.
how is offline   Reply With Quote
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 06:01 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 07:42 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 02:12 PM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 11:42 PM
