Old 03-05-2012, 08:50 PM   #16
Furnace is condensating?
Originally Posted by Andrew W View Post
Nothing last night/ 3 a.m. this morning... I dont know if you got the message about the coils underneath the furnance for the air conditioning... could the hot air mix with the (cool) coils causing condensation backing up in the furnance?
no that is not your problem...explain the operation as you see it...inducer comes on,,small delay as pressure switch pulls in...ignitor glows...pilot lights...5-10 sec burnners light.......
Old 03-05-2012, 08:50 PM   #17
Depending on how long i wait to check it ... sometimes a few drops... sometimes... more than a few drops...
Andrew W is offline   Reply With Quote
Old 03-05-2012, 08:52 PM   #18
GC/Master Plumber/Mech
Nope it won't effect that at all.
This hose directly linked to the heat exchanger only.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 03-05-2012, 08:52 PM   #19
plumber 101 mentioned check flue at top of furnace...may be bird got down..
The Following User Says Thank You to ben's plumbing For This Useful Post:
Plumber101 (03-05-2012)
Old 03-05-2012, 08:56 PM   #20
i wake up around 3 am... no heat through vent. turn off thermonstat... wait 10ish 15 minutes. turn on thermonstat... the filament glows red fire comes on for a few then turns off... i turn off thermonstat and back on... filament glows red... a blue flame comes on... wants to turn into fire but eventually goes out
Old 03-05-2012, 08:58 PM   #21
This problems seems to ONLY HAPPEN at night time when the temperature drops.. (when its really cool outside) because other nights it works just fine...
Old 03-05-2012, 09:00 PM   #22
that also looks like original ignitor/ senser ..could be this not sensing pilot going into lock out... could also be bad smartvalve...
don't explain why only does it at nite..
Old 03-05-2012, 09:04 PM   #23
want me to take a picture of it? The sensor is on the other end of the orange tube right?
Old 03-05-2012, 09:06 PM   #24
dirty pilot assy??
Old 03-05-2012, 09:07 PM   #25
no the senser is with the ignitor .thats the part that glows red..this is not making any sense....only fails at nite..........
Old 03-05-2012, 09:07 PM   #26
had the piolot cleaned etc...
Old 03-05-2012, 09:09 PM   #27
Yes usually fails at night...
Old 03-05-2012, 09:15 PM   #28
Iam leaning towards a bad smartvalve or ignitor assy..only explanation.
Old 03-05-2012, 09:18 PM   #29
Has nothing to do with the air conditioning coils being directly underneath the heater?
Old 03-05-2012, 09:22 PM   #30
not really if the furnace over heats it trips the limit switch but then the switch cools down and resets itself and furnace restarts...from what you say when blue pilot lites..it is suppose to tell flame senser to light burnners...it does not..it goes out....this function is controled by the smartvalve...
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 06:01 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 07:42 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 02:12 PM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 11:42 PM
