Old 03-05-2012, 07:42 PM   #1
Furnace is condensating?
During the night, my furnance shuts off (the piolot has a hard time lighting again and the house gets cold. I also notice there's water that is in a tube connecting the fan and the (thromoeter) Why is there water backing up in my furnance?
Andrew W is offline   Reply With Quote
Old 03-05-2012, 07:47 PM   #2
get us a picture of furnace with door off so we can see what your talking about???
Old 03-05-2012, 08:06 PM   #3
going to send a pic now
Old 03-05-2012, 08:12 PM   #4
I think I sent this picture right... water is in the red tube
Old 03-05-2012, 08:18 PM   #5
good picture andy... you say you have water in orange tube...pull tube off inducer and clean out the little port....also go to other end of tube at pressure switch make sure tube is not cloged.. thats a inner city product...tempstar,heil.. right
Old 03-05-2012, 08:24 PM   #6
GC/Master Plumber/Mech
It's an older ICP product.
Haven't seen a collector box for sometime now. If you are getting water in the orange tube and you shouldn't because this is an 80% furnace. I would check the flue for a restriction.
John Wayne once said "Life is tough and it is even tougher if you are stupid"
Tempstar and Trane Dealer
Old 03-05-2012, 08:24 PM   #7
port is connected to the fan, right.. how do i clean this?
Old 03-05-2012, 08:27 PM   #8
Just remove the orange hose and blow through the hose. Look at the ports where the hose connected and look for a blockage.
The bigger picture is that you said there is water in the hose and this is NOT a condensating furnace.
Old 03-05-2012, 08:30 PM   #9
I remember these units I also remember there was alittle water in tube but not enough to interfere with operation ....i
The Following User Says Thank You to ben's plumbing For This Useful Post:
Plumber101 (03-05-2012)
Old 03-05-2012, 08:32 PM   #10
yes connected to fan pull off get small peice of wire or something push into port back and forth
Old 03-05-2012, 08:33 PM   #11
that is the original inducer fan in furnace,...is it making any noise...
Old 03-05-2012, 08:36 PM   #12
I believe its starting to make noises that I'm not used to...
Old 03-05-2012, 08:38 PM   #13
that may explain the water in tube ..but sill should operate because its closing pressure switch.....how much water in tube,,,,just a few drops?
Old 03-05-2012, 08:41 PM   #14
If I had a dollar for every bird that falls to it's death down a flue pipe. I'd have about $20. Check the flue to make sure it still has it's cap in place. You may have a weak inducer motor.
The only way to know is to measure the pressure of the inducer. You will need a manometer to check the pressure. Inch of Water Column (In wc)
Old 03-05-2012, 08:46 PM   #15
Nothing last night/ 3 a.m. this morning... I dont know if you got the message about the coils underneath the furnance for the air conditioning... could the hot air mix with the (cool) coils causing condensation backing up in the furnance?
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 06:01 PM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 07:42 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 02:12 PM
Olsen BFL 120 Furnace DaleB HVAC 12 12-19-2008 11:42 PM
