-   -   Furnace is condensating? (http://www.diychatroom.com/f17/furnace-condensating-136083/)
Andrew W 03-05-2012 07:42 PM
During the night, my furnance shuts off (the piolot has a hard time lighting again and the house gets cold. I also notice there's water that is in a tube connecting the fan and the (thromoeter) Why is there water backing up in my furnance?
ben's plumbing 03-05-2012 07:47 PM
get us a picture of furnace with door off so we can see what your talking about???
Andrew W 03-05-2012 08:06 PM
going to send a pic now
Andrew W 03-05-2012 08:12 PM
1 Attachment(s)
I think I sent this picture right... water is in the red tube
ben's plumbing 03-05-2012 08:18 PM
good picture andy... you say you have water in orange tube...pull tube off inducer and clean out the little port....also go to other end of tube at pressure switch make sure tube is not cloged.. thats a inner city product...tempstar,heil.. right
Plumber101 03-05-2012 08:24 PM
It's an older ICP product.
Haven't seen a collector box for sometime now. If you are getting water in the orange tube and you shouldn't because this is an 80% furnace. I would check the flue for a restriction.
Andrew W 03-05-2012 08:24 PM
port is connected to the fan, right.. how do i clean this?
Plumber101 03-05-2012 08:27 PM
Just remove the orange hose and blow through the hose. Look at the ports where the hose connected and look for a blockage.
The bigger picture is that you said there is water in the hose and this is NOT a condensating furnace.
ben's plumbing 03-05-2012 08:30 PM
I remember these units I also remember there was alittle water in tube but not enough to interfere with operation ....i
ben's plumbing 03-05-2012 08:32 PM
yes connected to fan pull off get small peice of wire or something push into port back and forth:yes:
ben's plumbing 03-05-2012 08:33 PM
that is the original inducer fan in furnace,...is it making any noise...
Andrew W 03-05-2012 08:36 PM
I believe its starting to make noises that I'm not used to...
ben's plumbing 03-05-2012 08:38 PM
that may explain the water in tube ..but sill should operate because its closing pressure switch.....how much water in tube,,,,just a few drops?
Plumber101 03-05-2012 08:41 PM
If I had a dollar for every bird that falls to it's death down a flue pipe. I'd have about $20. Check the flue to make sure it still has it's cap in place. You may have a weak inducer motor.
The only way to know is to measure the pressure of the inducer. You will need a manometer to check the pressure. Inch of Water Column (In wc)
Andrew W 03-05-2012 08:46 PM
1 Attachment(s)
Nothing last night/ 3 a.m. this morning... I dont know if you got the message about the coils underneath the furnance for the air conditioning... could the hot air mix with the (cool) coils causing condensation backing up in the furnance?
