Furnace Condensate Drain/trap Help Needed - HVAC - DIY Chatroom Home Improvement Forum
Old 01-08-2012, 04:24 PM   #1
Furnace condensate drain/trap help needed
Greetings, I recently moved into a house with a Carrier Weathermaker 9200, and planned on installing a bypass humidifier. While preparing to run the drain line, I noticed the peculiar arrangement of the condensate drain line, & what worried me the most was the trapped drain line running from the exhaust vent, which looks to be original & done at the time of installation. Is this proper procedure? This exhaust drain & the furnace condensate drain join together & deposit into the (non trapped) AC drain line & exit in the sump pit. Other than the miniscule amount of water in the trap, I donít see what keeps exhaust from leaking into the house.
Iíd be happy to hear some advice/suggestions on this matter.
EW57 is offline   Reply With Quote
Old 01-08-2012, 04:56 PM   #2
MarginallyQualified
Rewards Points: 2,464
Originally Posted by EW57 View Post
...what worried me the most was the trapped drain line running from the exhaust vent...
I don't think it matters a whole lot...
but I'm a bit OCD and that would bug me as well.
$5 spent on some new fittings and we can both sleep better.
Old 01-08-2012, 05:10 PM   #3
If you look closely to the left side of that picture, you will see the condensate TRAP supplied by Carrier, the trap at the bottom of the flue pipe i am betting is left over by lazy installers who didn't feel like re-working a exhaust pipe. As in any trade, we too have hacks who just don't care.
harleyrider is offline   Reply With Quote
Old 01-08-2012, 05:16 PM   #4
Originally Posted by harleyrider View Post
...the trap at the bottom of the flue pipe i am better is left over by lazy installers who didn't feel like re-working a exhaust pipe. As in any trade, we too have hacks who just don't care.
Thanks for the reply, is the exhaust supposed to be drained this way? It doesnt take long for the exhuast to expel the water in the trap & start pushing exhaust through. Should the trap be longer/larger?
Thanks again!
Old 01-08-2012, 07:21 PM   #5
Thanks again!
At this point just leave it....but its an extra un-needed trap.
Old 01-09-2012, 04:21 AM   #6
An old Tradesmen
Rewards Points: 6,086
Yes, the exhaust is supposed to be trapped.
Old 01-09-2012, 08:50 AM   #7
On a Carrier, the exhaust is trapped through the venting system, into a Factory supplied trap (as in the picture on the left).
Old 01-09-2012, 04:44 PM   #8
An old Tradesmen
On long vent runs(specially if its unconditioned), you need to have that drip tee like they have. And it needs a drain, and a trap.
Old 01-09-2012, 04:59 PM   #9
Hvac Pro
yuri's Avatar
Rewards Points: 1,096
there is not enough pressure to blow the water out of the trap on the drain pipe and there is lots of condensation/water in the exhaust to refill it. York and a few other models use a drip tee to get rid of condensation in the exhaust so it is just fine. 99% or more of the furnaces running are producing no CO in their exhaust or a very tiny amount. a properly burning furnace gives U water vapor/H20 and CO2 not C0. the C0 is when there is improper combustion/shortage of oxygen to the burners or other bad conditions which you should not have.
Condensate Pump confusion GlennAndrew HVAC 9 01-01-2010 06:25 PM
Oil furnace does not fire up sbhavinm HVAC 5 01-17-2009 08:06 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
KNOWLEDGABLE condensate advice needed Nestor_Kelebay HVAC 5 11-23-2008 08:06 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
