Furnace Coming On, Then Going Off - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 10-05-2008, 01:10 PM   #16
little update.... i was monkeying around and took off the cover to my curcuit board and lo and behold it looks as though my roof was leaking into my furnace area and dripped onto the board. We have had a crapload of rain here lately and it looks like it has rusted out some of the contacts on the board. i believe i have probably found my problem. off to fix the roof and order a new board. i don't understand why this hasn't made the self diagnostic light go off though. oh well.
Boulderv7 is offline   Reply With Quote
Old 10-05-2008, 01:23 PM   #17
Electrician
SD515's Avatar
Rewards Points: 504
Originally Posted by Marvin Gardens View Post
Just about any hardware store has them. They are called thermocouples.
Measure the length of the one you have and get one that is close to that. They are all the same with a few rare exceptions.
If you have a multimeter you can actually check to see if it's functioning. But my money is that it is toast and for about $5 you can make sure that isn't it.
FYI....The OP's furnace sounds like it's HSI...in which case it doesn't have a thermocouple, but has a flame sensor.
Kyle
Old 10-05-2008, 01:28 PM   #18
Electrician
SD515's Avatar
Rewards Points: 504
If you think about it...a 'fried' board isn't going to work properly...if it fried some sections that relate to self-diagnosis, it isn't going to be able to flash codes.
Kyle
Old 10-05-2008, 01:31 PM   #19
I am confused with another poster who has a pilot light that keeps going out.
Guess I am too old to carry on more than one conversation at a time.
"A man's got to know his limitations." Dirty Harry.
Marvin Gardens is offline   Reply With Quote
Old 10-05-2008, 01:33 PM   #20
Flame sensors are far from being anything like thermo couples. And hardware store do not carry them.
A thermocouple produces a DC current in millivolts that holds open the pilot coil (like a solenoid) so that the main gas valve will energize when the thermostat closes to allow passage of 24v current. When that occurs the main 24v gas valve unseats and allows gas to flow to burners.
A flame sensor send a rectified dc signal to the main board that is measured in micro amps, that MILLIONTHS of an amp.
If sensor is dirty that signal cannot pass to the board resulting in burner shut down.
I can recommend some tech materials if you would like to be brought up to speed on furnace controls.
hvaclover is offline   Reply With Quote
Old 10-05-2008, 01:40 PM   #21
Obviously you didn't read the post my post after that.
Is this an alpha dog thing???
Old 10-05-2008, 01:51 PM   #22
Naw, I either missed it or it got posted while I was typing my response.
Was just trying to be helpful.
Old 10-05-2008, 01:54 PM   #23
I appreciate your help. I just got lost in my postings.
I find that more and more as I get older. I am doomed. Every one in my family had dimentia and I am sure I am headed that way which really sucks.
Old 10-05-2008, 01:56 PM   #24
Yeah I just checked the time on your post,, your correction got posted while i was still typing.
I am just too slow on this key board.
Old 10-05-2008, 02:00 PM   #25
HA join the club. Last night as iwas cleaning away the dinner plates I put the Vinegar in the frig and the butter in the cup board
Any way no harm intended.
Old 10-05-2008, 03:05 PM   #26
My wife watched me as I put the cereal in the fridge and the milk in the cabinet the other day. I never even caught it and she had to point it out to me.
I am guessing that in a few years I will still be thinking that all the new electronic furnaces will have thermocouples.
The really sad part is that no one will be able to tell me otherwise.
Old 10-05-2008, 03:17 PM   #27
There's new med's that alleviate those mild symptoms. You just have to decide if the side effects are worth the memory improvement.
Old 10-05-2008, 03:44 PM   #28
Electrician
SD515's Avatar
Rewards Points: 504
I have my share of senior moments at times myself...ain't no thing to worry about. The trick is to limit the number that other people see...lol.
Kyle
Old 10-05-2008, 04:46 PM   #29
I am working on that part. I told my wife to get out yesterday.... Just kidding. She keeps me sane and I would crumble after 30 years of marriage.
Currently I am bored and just sitting around between projects. I am answering at least 10 posts a day here and am getting confused as to what post I am responding to.......
Need to simplify....a simple life is good....must smash computer now.....sit in corner and suck thumb with blankey.....
Old 10-05-2008, 04:55 PM   #30
Electrician
SD515's Avatar
Rewards Points: 504
LMAO !! Ok Linus !!
Kyle
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 08:01 PM
Add-on Wood furnace billmac HVAC 3 06-18-2008 10:17 PM
Furnace troubles, where's the water coming from... Head Scratcher HVAC 10 03-23-2008 08:40 PM
oil furnace problem Dave80 HVAC 1 01-24-2008 08:53 AM
water coming out of my furnace hmsmc1009 General DIY Discussions 4 07-14-2007 11:53 PM
