-   -   Furnace combustion chamber replacement (http://www.diychatroom.com/f17/furnace-combustion-chamber-replacement-30315/)
tripower 10-21-2008 09:31 AM
I had my oil company's tech come out to do a cleaning on the furnace.
He pulled the combustion chamber only to find a gaping hole burned thru it.
Quoted me $621 for part and install. Sound reasonable?
The furnace is a Hallmark. Honestly this looks like something I could do myself.
Does anyone know of a part supplier for Hallmark furnaces? Other recommendations?
Marvin Gardens 10-21-2008 10:48 AM
This seems reasonable to me.
Part is probably $300-$400 (guessing based on previous experience). His cost to put it in is probably $100-$200.
I charge $125 for a service call.
I'm surprised he didn't shut it down as this is a CO problem and is potentially dangerous and could cause death.
Then again I know firefighters who underestimate CO so I guess a furnace person is not expected to understand that.
Mainah 10-21-2008 06:39 PM
a combustion chamber and heat exchanger are two different things-
if you continue to run the furnace with a hole in the chamber it will eventually burn thru the exchanger, then co will be an issue.
don't run your furnace, you will save yourself a much bigger repair bill-
the price to replace the chamber is right in line with what our company would charge-
