Old 10-29-2007, 09:03 PM   #1
Question
Furnace Combustion Chamber
On my furnace there is a caution sticker that states to neither vacuum, clean, or otherwise damage the ceramic fibers of the combustion chamber.
First, I have to ask why? Second, there were numerous flakes (of I am assuming ceramic fibers), based on the warning message I am assuming I should just leave them there? And is this normal?
tripower is offline   Reply With Quote
Old 10-30-2007, 12:48 PM   #2
Probably just a CYA warning. Unless they're working on a furnace with a hard ceramic chamber like a Thermopride or Hallmark, many techs that don't know what they're doing damage soft combustion chambers in furnaces, or damage door refractory, target wall refractory and bottom blankets in boilers. Soft furnace combustion chambers are generally damaged by vacuum hoses and flexible metal extensions. Boiler refractory is often damaged by soot saws and brushes as well as by vacuum.
MarkJames is offline   Reply With Quote
Old 10-30-2007, 05:47 PM   #3
I appreciate the post although I didn't understand much of what was said. I have a Hallmark by the way. Are you saying I have a hard ceramic chamber or soft?
Old 10-30-2007, 05:56 PM   #4
Home Improvement Guy
ron schenker's Avatar
Mark must be a pro HVAC guy with all that technical Jargon
ron schenker is offline   Reply With Quote
More On This Topic
What Do Spark Plugs Do?
What Do Spark Plugs Do? by Expert Village
Hi my name is John, on behalf of Expertvillage.com. In this video clip I will explain what spark plugs actually do. As we take a look at this engine cut away there is a couple of things I wanted to point out, right here we have the piston and we have our... Read More »
Properly functioning spark plugs are essential to the life and reliability of your vehicle. The spark plugs provide a spark so the fuel can combust, allowing the engine to continue running. It is important to check the quality of your spark plugs with... Read More »
Hi, this is Jon on behalf of Expert Village. In this video clip, I'll be talking about extension cords. There is a lot of cases where you're going to need to use your vacuum in a place that is a long distance from an electrical outlet. In this case, you... Read More »
Depending on where you live in the United States, you may encounter high monthly bills for heating your home. Many homes in warmer climates are built with wide windows and open floor plans, so unexpected low temperatures often result in cold, drafty... Read More »
Hi! My name is Matthew Christian from Tampa, Florida and on behalf of Expert Village, today I would like to talk to you about how to properly use and maintain a high limb chainsaw. Most yard tools or power lawn tools that are gas are two cycle meaning... Read More »
Heil Furnace Burner Problem timothyr HVAC 65 10-26-2009 04:49 PM
Bryant Furnace main burner goes out after 5 seconds Da_Bears HVAC 4 01-26-2008 09:20 PM
Replacing My Furnace, few simple questions compression HVAC 10 02-03-2007 06:00 PM
Could installing a furnace to the floor joists cause the floor to slope? JKL HVAC 5 01-03-2007 10:23 PM
Furnace does't start when Fan is 'auto' stepicz HVAC 2 10-18-2005 07:10 AM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
