Furnace Closet Vent-not Sure? - HVAC - DIY Chatroom Home Improvement Forum
Old 11-11-2010, 11:27 AM   #1
Furnace closet vent-not sure?
The closet the furnace sits in has a 12x6 vent in the floor which blows cold air from crawl space below. There are big open spaces in ceiling leading to attic. They stuffed some fiberglass in gaps and called it good. You can hang meat in there in winter. I want to close up all the openings. The furnace is a Lennox model EZ-1625. The supply and exhaust pipes are PVC and I assume makes it a 90% furnace. The heated air connects from the top of unit while the return air comes through duct under furnace. There is also a floor level retun below the furnace that tee's into the return air duct. The house was built in 50's so open space to attic and crawl space...well don't know??? Is it safe to make closet air tight when dealing with gas and co??? Home owner trying to be safe. Thanks People
kona-man is offline   Reply With Quote
Old 11-11-2010, 12:31 PM   #2
HVAC / Plumbing
if you have an intake (combustion air) pipe & an exhaust pipe. then you can make that area air tight. Provided you have no other gas burning appliance in that room
kenmac is offline   Reply With Quote
Old 11-11-2010, 04:16 PM   #3
Thanks Kenmac...yes there is one supply and one exhaust 2 inch pipes that pass through attic and terminate about 2 1/2 feet above roof. The only thing in the closet is the furnace. Would it be wise to install a CO and Gas detector in the closet? Again Thanks
Old 11-22-2010, 11:47 AM   #4
Direct vents
Kenmac,
You say you can close up the vents in this application. In so many words, this is becasue the furnace is a direct vent unit which gets its combustion air from the sealed outside vent. Great. Now, is this true for a gas direct vent water heater? One would sure think so. If not, why not?
bob99 is offline   Reply With Quote
Can I vent furnace through window? praprade HVAC 27 10-04-2010 09:02 PM
Furnace and air vent problems dsd HVAC 3 06-15-2010 07:28 AM
90% Furnace Vent Lines tk707 HVAC 3 01-13-2009 08:56 PM
Is my furnace a direct vent or power vent? wease HVAC 5 02-02-2007 07:55 AM
