Furnace Closet Question - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 08-12-2012, 12:39 PM   #16
It's to heat both
Talgonadia is offline   Reply With Quote
Old 08-12-2012, 07:14 PM   #17
If it's free...It's me
Originally Posted by turnermech View Post
Get another opinion there has got to be a better way than that.
I agree...Someone else has to know of a better way. Sealed duct work is better than the void between the basement ceiling and the first-floor floor. Since that furnace is multipositional there must be a way they can attach the ductwork for both return and supply even if they do not run it down the center of the house. Perhaps next to the beam?
Johnny'sHotDogs is offline   Reply With Quote
Old 08-12-2012, 07:16 PM   #18
If they run both it will lower the ceiling height to 6 ft 5 inches. That's under code
Old 08-13-2012, 08:16 AM   #19
I measured the beam it's 94inches from cement to center beam. I plan to use carpet in the basement to get the most ceiling height. 94inches is only 7ft 10inches. To the left and right of the beam I have about an extra inch. So 95in minus 8 for the supply duct makes 87inches. That leaves me at 7.25ft. If we add a return duct then the feeds off the supply duct have to go under the return duct. They said the feeds were 6inches of round tubing...
Now I have an idea that will enclose the duct to the beams which will then create a return duct. My only issue with that would be wiring would be in it which if I read is not up to code.
Gas furnace exhaust vent question nowell HVAC 7 01-30-2012 08:31 AM
Furnace pressure switch line/nipple question aparman HVAC 4 12-31-2011 04:27 PM
Heil furnace inducer vibrating, capcitor handling question diggerdave HVAC 45 03-01-2009 04:56 PM
York PM9 Mod Furnace, Aux Fan Question javan HVAC 20 02-10-2009 08:22 AM
Question Re: New Furnace and Duct Sizing DSimo HVAC 3 06-17-2008 07:24 AM
