Furnace To Cased Coil Connection... - HVAC - DIY Chatroom Home Improvement Forum
Old 10-11-2010, 02:24 PM   #1
Furnace to Cased Coil Connection...
How should the connection between an upflow furnace and a cased coil be made? Do you screw them together? Do you typically seal the joint with a gasket or tape? Thanks.
civiltoatee is offline   Reply With Quote
Old 10-11-2010, 05:05 PM   #2
HVAC / Plumbing
Originally Posted by civiltoatee View Post
How should the connection between an upflow furnace and a cased coil be made? Do you typically seal the joint with a gasket or tape? Thanks.
I don't use any screws.. Just seal/tape
kenmac is offline   Reply With Quote
Old 10-11-2010, 05:34 PM   #3
An old Tradesmen
Rewards Points: 7,780
Caulk.
Old 10-11-2010, 08:47 PM   #4
Thanks, caulk sounds like a great idea, any particular type?
Old 10-11-2010, 08:51 PM   #5
HVAC / Plumbing
I use silicone
Old 10-11-2010, 08:55 PM   #6
An old Tradesmen
Originally Posted by kenmac View Post
I use silicone
Yep. Any good silicone will work.
Old 10-11-2010, 09:03 PM   #7
Hvac Pro
yuri's Avatar
Rewards Points: 98
Not the stuff you buy at the dollar store. Buy a high grade at HDepot. Your plenum can run up to 200 degF. Over a period of time the cheap stuff may fall apart.
Old 10-11-2010, 09:04 PM   #8
An old Tradesmen
I did say good. Didn't I .
LOL
Old 10-11-2010, 09:07 PM   #9
HVAC / Plumbing
LOL
Does that mean I have to stop using silicone I get at the yard sales ???
Old 10-11-2010, 09:16 PM   #10
An old Tradesmen
Atleast the stuff you scraped off the windows.
Old 10-11-2010, 09:18 PM   #11
HVAC / Plumbing
Ever heard of recycling ??
Old 10-11-2010, 09:57 PM   #12
Silicone it is. Thanks.
Furnace air filtration advice stephen_smith HVAC 7 12-24-2010 02:24 AM
Evap coil question merlinfolks HVAC 15 07-27-2009 07:20 AM
Bryant +80 Gas Furnace won't light tr0910 HVAC 4 01-14-2009 07:11 AM
Add-on Wood furnace billmac HVAC 3 06-18-2008 09:17 PM
installing new rheem furnace to old a coil rad488 HVAC 1 10-17-2007 08:07 PM
