Furnace & A/C Brands - HVAC - Page 3 - DIY Chatroom Home Improvement Forum
Old 11-07-2012, 04:05 PM   #31
Rewards Points: 380
This same argument has gone on for years here. Yes there is a lot of merit to a manual J, yes there is also merit to 1000 installs under your belt etc. but the truth of the matter is people will buy for a variety of reasons, price is a factor, brand can be a factor, who impresses them with the most information can be a factor, but most people buy from who they feel that they can trust. Now if we could only be sure that those they trust would do a good job of the install.
HVACDave is offline   Reply With Quote
The Following 3 Users Say Thank You to HVACDave For This Useful Post:
ben's plumbing (11-07-2012), Technow (11-07-2012), yuri (11-07-2012)
Old 11-07-2012, 05:07 PM   #32
Hvac Pro
yuri's Avatar
Rewards Points: 396
LIke setting it up properly, checking the gas pressure to make sure it is not under or overfired. Check temp rise so it does not ride the limit control etc etc.
Old 11-07-2012, 05:48 PM   #33
Hvac Pro
yuri's Avatar
Rewards Points: 396
Originally Posted by REP View Post
So where do you go for new horse shoes and buggy wheels?????
I'll bet you set up oil burners by eye too.What a joke,maybe someone should welcome you to the twenty first century.
Actually I prefer the CB method. I see a 45,000 BTU furnace in your future. BwaHaHaHa
Furnace & A/C Brands-crystal-ball.jpg
Old 11-07-2012, 05:58 PM   #34
Rewards Points: 582
well I may as well ***** alittle myself....went to a location to bid a furnace...i had already did 3-4 houses on same street 1 was the neighbor to the house i was bidding.....I was the only contractor to perform a manual j....2 others well known in the area bid also.....furnace was sized at 62,000 btu quoted 70,000 --95% .......after a week called to follow up...was told they were going with the other guy who was installing 90,000 95%....go figure.... the point to this disscussion ..some people will not take our word even if we do a proper sizing of equiptment......so you all stop fighting..ben sr
The Following User Says Thank You to ben's plumbing For This Useful Post:
Old 11-07-2012, 06:24 PM   #35
Rewards Points: 616
not fighting..... just don't believe in a manual J.....
carmon is offline   Reply With Quote
Old 11-07-2012, 06:30 PM   #36
JJboy's Avatar
Do you believe in someone from old school??....You got be kidding.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 11-07-2012, 06:42 PM   #37
Rewards Points: 616
I am old...... old as dirt almost....
Old 11-07-2012, 07:39 PM   #38
Rewards Points: 616
and no I was not kidding......
The Following User Says Thank You to carmon For This Useful Post:
JJboy (11-07-2012)
Old 12-05-2012, 09:00 AM   #39
Rewards Points: 14
Hi all,
Thanks for the feedback and it sounds like this got pretty technical!
Wondering if I should spend the extra $$$ on a Carrier system vs a Goodman/KeepRite/etc.
I don't want to throw good money before bad, but if it's worth it I would definitely consider.
Any thoughts?
ldogg is offline   Reply With Quote
Old 12-05-2012, 09:38 AM   #40
Rewards Points: 484
I used to be a fan of Goodman but have lost faith over the years as I see their stuff built cheaper and cheaper. I think York and Lennox have some nice products out there, Nordyne is another decent one.
Nordyne= Maytag, Fridgidaire, Westing house, Tappan, Broan and so on.
sammy37 is offline   Reply With Quote
Old 12-05-2012, 09:55 AM   #41
Roofmaster
Rewards Points: 2,210
Does it still matter as much?
With todays modern furnaces that can run at high and low output, and have multi speed blowers, it would seem to somewhat negate the need for an exactly sized furnace, as long as it is big enough to do the job. Is this a fair statement to make?
Old 12-05-2012, 10:10 AM   #42
Hvac Pro
yuri's Avatar
Rewards Points: 396
If it is oversized then the blower will be too big for the ductwork. With an ECM motor the motor can only handle a certain amount of back pressure/resistance and then it will malfunction. With a conventional motor it will overload it.
Old 12-05-2012, 12:48 PM   #43
The multi stage furnaces are only rated at high fire. Lower fires have a 5 percent or greater loss in eff. on many models.
Old 12-05-2012, 06:00 PM   #44
Roofmaster
HVAC Calc
Do any of you pros use HVAC Calc? It seems to be quite comprehensive.
Old 12-05-2012, 08:08 PM   #45
Roofmaster
Same Question
I asked the same question here some time ago and all I ever got from this forum was that the installer is the most important thing. I would really tend to think that this is true with a new furnace. I am not sure how true it is if you are doing a replacement. I asked the pros if any of them had ever used a micrometer to measure the wall thickness of the heat exchangers, since heat exchanger failure would tend to render a furnace irreparable. (Everything else is third party and replaceable) I got no answer. I did get responses that all of the furnaces that a typical homeowner can buy online are of lower quality, and lower grade than dealer only models. I asked about Carrier, which I currently own, and am quite happy with, and some techs said that today they are made like crap. So what I did was download brochures and looked at how they are laid out inside, vis a vis ease of access, ease of changing out parts if needed, general construction, and heat exchanger warranty. I now know which one I am going to buy, and I recommend you do the same. One thing I did find out, which is very disturbing, is that all of them are made exclusively from parts made in other countries, even if they are assembled here. They may be more efficient than the old furnaces, but they sure aren't built as well.
Furnaces have gone the way of everything else in this country. Door hinges are brass plated, not brass anymore, hence the black iron dust near your hinges. Your plumbing fixtures go bad in 5 years, and your door lock sets wear out in about the same. No4 pine is now labeled as No.2, and your bed wears out in three years instead of 12. Roof shingles are rated by the number of years they lie about them lasting instead of by how much they weigh.
We got what we asked for ChiCheeChinkCrap. Now we have to live with it, because all the good stuff is gone forever.
Gas furnace brands, which is better, Comfortmaker, American Standard, and Lennox? abefroman HVAC 10 04-22-2014 06:03 PM
Moving furnace & redoing ducting cbrc5eric HVAC 0 02-09-2012 08:13 AM
Payne PG9YAB high efficiency 95% furnace water draining problem jchen64 HVAC 9 12-06-2010 06:42 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 06:43 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 01:12 PM
