Furnace Burners Won't Come On - HVAC - DIY Chatroom Home Improvement Forum
Old 12-07-2013, 02:54 PM   #1
Rewards Points: 22
furnace burners won't come on
I have a payne furnace with a metal box that contains the burners. The box has a face plate with a round sight glass. If I remove that face plate, the furnace works fine. As soon as I install the faceplate, the burners go out and the LED flashes an error code of 13. There is a sensor on the side of the box with 2 red wires, and what appears to be a reset button in the center. The button does not pop, so there is nothing to reset. If I want the burners to come on, I simply turn off the thermostat, remove the face plate, then turn on the thermostat. Any ideas what may be wrong?
johnmr12 is offline   Reply With Quote
Old 12-07-2013, 03:23 PM   #2
how
Rewards Points: 1,104
You should have a diagnostic legend inside the furnace (check the inside of the furnace doors) that will explain what the code means.
Removing the sight glass or sight glass will change the pressure differential so the code will probably reflect a pressure issue.
A faulting pressure switch/ hose lines/ ID motor or assy / vent obstructions/ or the heat exchanger are all possibilities
Let us know what the legend says is 13.
how is online now   Reply With Quote
Old 12-07-2013, 03:26 PM   #3
An old Tradesmen
Rewards Points: 8,174
Could be the combustion air intake is restriction, or the exhaust flue is restricted.
Old 12-07-2013, 03:52 PM   #4
Rewards Points: 22
The code says it is either a limit or flame roll out lockout. It says if its a limit switch issue, it will reset after 3 hours, which it didn't. If it's a flame roll out issue, it says to manually reset the switch or replace the fuse link. I'm pretty sure the flame roll out switch is the sensor on the side of the box, and as I said before, it doesn't require a reset. I'm not sure where the fuse link is.
Old 12-07-2013, 04:22 PM   #5
Rewards Points: 22
I went on the roof and there is no obvious obstruction in the exhaust flue
Old 12-07-2013, 04:26 PM   #6
An old Tradesmen
With the burner over off. Run the furnace and see if it completes a full heating cycle.
Also post full model number.
Old 12-07-2013, 04:31 PM   #7
Rewards Points: 22
With the cover off, a motor comes on as soon as I turn on the thermostat, then after about a minute, the igniter starts to glow, then the burners fire and another motor seems to come on. As long as the cover is off, the burners will continue to burn and the heat comes through the vents. The model number is PG9MAA
Old 12-07-2013, 04:49 PM   #8
An old Tradesmen
Is this burning LP/propane?
Old 12-07-2013, 04:50 PM   #9
Rewards Points: 22
Sorry, yes it uses propane.
Old 12-07-2013, 04:53 PM   #10
An old Tradesmen
Secondary heat exchanger may be plugging up with soot.
Old 12-07-2013, 04:56 PM   #11
Rewards Points: 22
Can you tell me how to unplug it? what does it look like?
Old 12-07-2013, 06:46 PM   #12
An old Tradesmen
The collector box for the secondary is what the inducer/combustion blower is connected to. You need to remove the inducer, and inspect the secondary heat exchanger.
Old 12-08-2013, 01:29 PM   #13
Rewards Points: 22
The furnace is in my garage, and the daytime temps here have been below 10 degrees for about 3 days, which is coincidentally when the heater stopped working. I had no idea that water was a part of this unit, but there is a hose coming from the secondary heat exchanger to an external pvc pipe which appears to drain excess water. That hose is full of ice. I'm going to assume that's my problem, so does anyone know the easiest way to remove or melt the ice without having to take out the motor which sits in front of it? and how do I keep it from freezing again?
Old 12-08-2013, 01:51 PM   #14
An old Tradesmen
Use heat gun/hair dryer. Then install a condensate pump and pump the water to a sanitary drain. Insulate the pump.
Old 12-08-2013, 01:55 PM   #15
Rewards Points: 22
Thanks, I will do that. When the heater is running, is the water in the system hot? In other words, if I have the thermostat set to 70 degrees and the furnace is continually cycling on and off to keep the house at 70, would that prevent the water from freezing?
Gas Furnace - Only First Two Burners Fire (Video Included) mark2741 HVAC 11 11-20-2012 09:51 PM
90-year-old Furnace Burners won't light asenada HVAC 15 10-24-2012 01:51 PM
Furnace Burners Flicker On and Off EDOinHB HVAC 19 02-22-2012 05:55 PM
Gibson furnace burners don't work rockyzys HVAC 4 12-21-2011 06:10 PM
Furnace burners flame out after a few seconds snurb HVAC 3 01-13-2009 07:58 AM
