Furnace Burners Shutting Off - HVAC - DIY Chatroom Home Improvement Forum
Old 03-06-2012, 11:12 PM   #1
Furnace burners shutting off
I have been working on two York packaged rooftop units model # D1HG060 with intermittent pilot ignition and both have the exact same problem. When I set the units for heating everything runs smoothly, but after 5 minutes the burners shut off and there is no voltage on the ignition control. After 5 minutes the burners ignite again then shut off after a few minutes and the cycle continues. I did change the ignition control and filters on one of the units but it did not fix the problem. If anybody can help me it would be great.
ocelot75 is offline   Reply With Quote
Old 03-06-2012, 11:29 PM   #2
Sounds like the high limit is being tripped. Could be a few different things. Did you clock both units?
hvac benny is offline   Reply With Quote
Old 03-06-2012, 11:46 PM   #3
how
Rewards Points: 1,104
Both units having the identical problem is odd. Is there a flashing led on a board that is giving a diagnostic fault code?
You can eliminate the thermostat as the culprit by jumpering R to W at the furnace thermostat connections while the thermostat is off to see if the unit still short cycles after 5 minutes.
If nothing changes then the pilot flame rods should be cleaned.
Next you need to meter which safety control is causing the lockout.(pressure switch, roll outs, all limits,
Does the blower run continually throughout the short cycle?
how is offline   Reply With Quote
gas furnace, burners wont stay on mikerva HVAC 3 01-19-2012 04:01 PM
furnace wattage (nat gas burners) BlueBSH HVAC 7 12-17-2011 11:43 AM
Fraser Gas Furnace Burners stopped lighting AZLambdaK1 HVAC 3 11-23-2010 03:34 PM
Dayton Gas Furnace burners wont stay lit Marie1313 HVAC 38 10-08-2009 04:38 PM
American Standard Freedom 80 Furnace not igniting all 4 burners chetw66 HVAC 2 09-25-2009 05:01 PM
