Furnace Burner Problem - HVAC - DIY Chatroom Home Improvement Forum
Old 01-11-2010, 07:24 PM   #1
furnace burner problem
i have an electronic control gas furnace and am experiencing a main burner problem. Everything appears to be working properly except for the fact that after the igniter fires up the 1st of three burners; the second burner and subsequently , the 3rd burner (containing the flame sensor) does not always fire up. With the 3rd burner not firing up, the flame sensor alerts the electronic control system and shuts down the furnace. This doesn't always happen , but sometimes it does. Its to cold in Michigan right now for a furnace problem. My question is....What causes the flame to travel from burner #1 to the other burners? If I manually light the second burner the 3rd burner lights...the sensor recognizes flame , and the furnace runs perfectly. Help would be appreciated very much. Thanks, Brent
brent h is offline   Reply With Quote
Old 01-11-2010, 07:34 PM   #2
There's a slot in front of the burners for the flame to travel from one burner to another,called a crossover. Take the burners out and clean them up real well, including all the crevices.
Old 01-11-2010, 07:50 PM   #3
thanks Marty. I'll pull the crossover assy off and clean the end of it really good....and hopefully the problem will be solved. Brent
Heil Furnace Burner Problem timothyr HVAC 79 02-12-2014 07:01 PM
Perplexing problem, Ruud furnace jbarker HVAC 43 01-20-2010 12:03 PM
Problem with Trane gas furnace quovadis HVAC 17 12-22-2008 01:12 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
Furnace Problem JASPER2008 HVAC 9 11-22-2008 08:54 PM
