Old 12-24-2009, 02:52 PM   #1
Furnace burner flame color
Can outside conditions change the burner flame color? I have a direct vented and fresh air from outside high efficiency furnance... was watching the flame color last night through the peep hole and it was burning a lot more orange then normal... but the day before it was pure blue, and today I looked again and it is pure blue, it seems the colder it is outside the more orange it burns... is there something to this or something else going on here?
BlueBSH is offline   Reply With Quote
Old 12-24-2009, 03:08 PM   #2
JohnH1's Avatar
Yes the wind can affect the burners like you are describing. Watch them durring 1st start up and pay close attention when the main blower starts. If the blower affects the burners you have a problem. Otherwise it is just the wind.
JohnH1 is offline   Reply With Quote
Old 12-24-2009, 03:10 PM   #3
That's pretty much what I was looking for with the blower last night, and it didn't affect the flame at all.. so I think my heat exchangers are in good shape at least from the quick look at them... just couldnt figure out why I was getting almost a pure orange last night as opposed to what I normally see
Old 12-24-2009, 05:08 PM   #4
HVAC Tech/ Browns Fan
Note When it very cool ouside you and everybody on your street is sucking that main gas line. That will lower the pressures and may cause flame be lower with diffent colors.
Tator1076 is offline   Reply With Quote
Old 12-24-2009, 05:12 PM   #5
Hvac Pro
"Peak shaving". Some utilities add a small amount of Propane to the gas to help maintain pressure and quantity when they have a maximum load or problem maintaining pressure. A bit of propane is harmless but looks orange/yellow.
Old 12-24-2009, 07:32 PM   #6
that all makes perfect sense, was just worried a little something happened to the burners, but after looking at them today with the cover off they looked ok and clean.. but the pressure issue I didn't even think about
Heil Furnace Burner Problem timothyr HVAC 78 01-18-2013 07:49 PM
Bryant Furnace main burner goes out after 5 seconds Da_Bears HVAC 8 01-03-2012 02:24 AM
Ruud furnace issue on upgrade board and flame sensor rubberman HVAC 22 01-16-2010 12:34 AM
Furnace flame color? Jboone HVAC 4 01-01-2009 07:21 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
