Furnace Blows Cold Air In Bedroom - HVAC - DIY Chatroom Home Improvement Forum
Old 11-30-2011, 06:19 AM   #1
Furnace blows cold air in bedroom
My house is a little over 3 years old and it has always been a little colder in the master bedroom than the rest of the house. Last night I think I finally figured out why. When the heater kicked on, the air coming out of the vents hit me and it was almost cold. I figured it would warm up as the heater ran but it never did. The air blowing in the master bathroom is the same. I went and felt the air in the kitchen and is was very warm and so are other vents in the house. So I went in the attic to check for kinked ducts or something and couldn't see anything but I don't know anything about what I'm looking at. I did notice that there is one duct that splits to two for the bedroom and another duct that splits to two for the bathroom and they are the first two ducts on the plenum but I don't know if that means anything. Is there some reason that these two ducts would/could be blowing colder than the rest of the ducts in the house?
ehuddle is offline   Reply With Quote
Old 11-30-2011, 05:41 PM   #2
A guy at works thinks that I might have leaks in my ducts but I can't find any. Does this make sense?
Old 11-30-2011, 09:20 PM   #3
how
Rewards Points: 1,104
If the vent is really blowing cold air beyond the initial store of a possible 10 seconds of cool air in the vent, then something is cooling down that one heating vent. (running through an uninsulated area, an uninsulated section of outside wall or running along side a dryer vent). Are all the duct lines in your attic warm to touch along there entire exposed length when the furnace is running? Can you identify the duct in the attic that is going to the master bedroom?
how is offline   Reply With Quote
Old 12-01-2011, 03:37 AM   #4
An old Tradesmen
Rewards Points: 8,154
Gas furnace or a heat pump? Pics of the ducts where they attach to the plenum would help.
Old 12-01-2011, 06:20 AM   #5
The ducts all seem warm to the touch. The duct to the bedroom is easy to see because all of the ducts are laying exposed in the attic. They are the insulated silver looking ducts that are soft on the outside and feel like they have a spiral wound wire inside them. The two cold ones have plastic y's where they split. I will get up there and get some pictures after work.
Old 12-02-2011, 03:28 PM   #6
It is an electric furnace, not a heat pump. In the picture, the two cold ducts are the ones on the right side of the plenum.
Old 12-02-2011, 04:48 PM   #7
Rewards Points: 6,652
First thing is, you need to straighten out that rats nest of ductwork. Then from the flex duct to vents, there should be hard elbow's at that point. From where they exit the airbox, there should be dampers between the flex duct and airbox.
Also, you do not have enough blown in insulation in that space. What would work out better, than having the unit in the attic, is if you could sacrifice some closet space up on the floor below the attic, and then run insulated hard duct work up and across the attic to each room. That would allow you to run returns through the floor below the air handler, to every room, except for baths and kitchen.
Can you post a floor plan, also temps taken at the supply and return of the air handler, then from each duct and return. You can use a kitchen thermometer to measure, or use http://www.lowes.com/pd_74930-56005-...ter&facetInfo= http://www.amazon.com/s/ref=nb_sb_ss...=airflow+meter
You can get a $40 from the first link, which is lowes.com. Now for what the time you take & the money, you could also have a environmental engineer do the same thing, and make sure that the duct work is up to snuff for your home.
Old 12-02-2011, 05:27 PM   #8
An old Tradesmen
Too close to the air handler. The design of the strip heaters allows air to blow by them and not be heated. A normal plenum would be longer, and allow time for the cold air and heated air to mix.
Old 12-02-2011, 06:49 PM   #9
Rewards Points: 582
wow what a mess...the flex duct should be pulled tighter,and have some fitting at the end of runs.....and as beenthere said...why no normal plenum.I would take it all apart and start over...you will be amazed at the better air flow and heating ability...ben
Replacing Furnace cold air return Copter17 HVAC 1 11-09-2011 03:07 PM
Trane unit not switching from heat pump to Furnace when weather gets cold. Jimw606 HVAC 1 09-27-2011 04:03 PM
furnace blows cold air but burner is workin drewhart HVAC 9 01-19-2011 08:22 AM
Lennox Furnace not working when very cold bsharitt HVAC 2 02-11-2010 05:58 PM
rheem split system blows warm for five minutes then cold queenie HVAC 1 06-15-2009 05:57 PM
