Furnace Blowing Cold Air Only - HVAC - DIY Chatroom Home Improvement Forum
Old 04-05-2012, 12:13 PM   #1
We have a Heil NUG5075bfb1 furnace. Last night the furnace was running but only blowing cold air. Everything seems to be working, but there is no heat. Upon checking, we noticed more of a gas smell than we ever have. Any ideas?
chilibean is offline   Reply With Quote
Old 04-05-2012, 12:36 PM   #2
Rewards Points: 14
Yeah, and they're all bad. Where do you smell gas, just in the furnace cabinet or in the main house? Don't fool around with it if it is in the main house. Turn off the gas and get out leaving a window or two and a door open and call someone from the neighbors house. Don't turn off any lights switches or equipment and don't use the phone.
GarryE is offline   Reply With Quote
Old 04-05-2012, 12:51 PM   #3
No, no gas smell in house. Only inside furnace.
Old 04-05-2012, 01:09 PM   #4
DIY Enthusiast
sublime2's Avatar
Rewards Points: 504
Either way CALL THE GAS COMPANY and get out of the house!
sublime2 is offline   Reply With Quote
Old 04-05-2012, 01:34 PM   #5
Rewards Points: 14
I believe this is a medium high efficiency unit that has a draft inducer or combustion air blower and a hot surface igniter. If you have your owners manual there should be a sequence of operation in there that you can follow. Quick check: Turnoff the power to the unit without changing anything, let the blower come to a stop then reenergize it. Does the blower come back on? If it does check for a lockout condition. Some of those units have diagnostic lights and a code listing sometimes inside the door or in the book. Most of them don't but check for a safety lockout reset, check that and also check your air filter dirty filters can cause nuisance lockouts.
AC not blowing cold air - was told have leak in coil- Cost? H.O.P. HVAC 3 05-17-2011 07:47 PM
cold air intake from outside to furnace... sspeed HVAC 8 03-19-2011 07:26 PM
Cold air in duct in furnace room? DIYguy2000 HVAC 6 12-23-2009 10:42 AM
Goodman furnace blowing lukewarm air mangust13 HVAC 12 02-19-2009 07:38 PM
Furnace blowing cold air. rileyc HVAC 4 02-19-2009 02:18 PM
