Furnace Blowing Cold Air. - HVAC - DIY Chatroom Home Improvement Forum
Old 02-18-2009, 06:14 PM   #1
Furnace blowing cold air.
I am having problems with my Comfortmaker Enviro 90 unit!!! It blows cold air until I switch off the unit for a few minutes. It will then work fine for a while then sounds like it is going to shut down after reaching proper temp. BUT it doesn't..just starts blowing cold air instead. I have had service techs come several times to no avail! Getting tired of waking up freezing cold....Can anyone help???
rileyc is offline   Reply With Quote
Old 02-18-2009, 07:31 PM   #2
scotch on the rocks
hvactech's Avatar
Sounds like either a flame rectification or board issue, next time it flips on you peek through the little hole located in the front panel and count the flashes before re-setting it, there is a legend somewhere inside the furnace that explains what the meaning of the flash codes .
hvactech is offline   Reply With Quote
Old 02-18-2009, 10:24 PM   #3
HvacWiz's Avatar
Rewards Points: 252
Either my eye site is going bad or you are using really small letters
HvacWiz is offline   Reply With Quote
Old 02-19-2009, 02:14 PM   #4
scotch on the rocks
hvactech's Avatar
Sounds like either a flame rectification or board issue, next time it flips on you peek through the little hole located in the front panel and count the flashes before re-setting it, there is a legend somewhere inside the furnace that explains whats the meaning of the flash codes just for you
Old 02-19-2009, 03:18 PM   #5
pull out your filter and take a look?
Most newer furnaces will blow cold air when a saftey is triggered. if your filter is dirty your furnace will over heat, trip the high limit and the fan will go on to coll the whole thing. once you reset it, it starts again, and over heats.
hughmacdiarmid is offline   Reply With Quote
A/C not blowing cold air... rnorred13 HVAC 9 04-03-2014 04:03 AM
Oil furnace does not fire up sbhavinm HVAC 5 01-17-2009 08:06 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 02:45 AM
