Old 01-17-2012, 07:00 PM   #1
furnace blowing cold air
I have a rheem criterion II furnace that is blowing cold air. It has two steady green lights. I have checked the filter and have turned off the gas valve as stated on the furnace and turned it back on. Is there an electronic pilot button to push, i did not see one
kathid is offline   Reply With Quote
Old 01-17-2012, 07:33 PM   #2
I'm Your Huckleberry
Do you have the manual or can you find the legend on or in the furnace which indicates what those two lights mean? There should be a legend.
Look inside the service doors.
Thanks.
Doc Holliday is offline   Reply With Quote
Old 01-17-2012, 07:37 PM   #3
Rheem Criterion II Flame on then off
According to this http://www.allreds.net/WS2/docs/rhe/rgph-man.pdf manual there is only one light..??
Find the legend on yours.
Thanks.
AC not blowing cold air - was told have leak in coil- Cost? H.O.P. HVAC 3 05-17-2011 08:47 PM
cold air intake from outside to furnace... sspeed HVAC 8 03-19-2011 08:26 PM
Cold air in duct in furnace room? DIYguy2000 HVAC 6 12-23-2009 11:42 AM
Goodman furnace blowing lukewarm air mangust13 HVAC 12 02-19-2009 08:38 PM
Furnace blowing cold air. rileyc HVAC 4 02-19-2009 03:18 PM
