Furnace Blower Will Not Shut Off - HVAC - DIY Chatroom Home Improvement Forum
Old 11-23-2011, 04:57 PM   #1
DRM
Furnace blower will not shut off
I have a Amana 90 air command furnace that is about 12 years old have replaced the control panel and now have replaced the limit switch. Furnace cycles on and off as it should but the blower runs constantly...and no the switch is not turned to run ..it is in the automatic position...help!
DRM is offline   Reply With Quote
Old 11-23-2011, 05:05 PM   #2
Milwaukeetool's Avatar
The way to tell where the problem is requires that the G wire at the furnace thermostat wire connection be removed. Turn power back on, if fan still runs it is most likely the circuit board blower relay. If it stops, it means somewhere in the stat or stat wire is a short from R terminal wire to the G terminal wire.
Milwaukeetool is offline   Reply With Quote
Old 11-23-2011, 05:13 PM   #3
Thats as goood a place to start as any.......
harleyrider is offline   Reply With Quote
Carrier Weathermaker Gas Furnace - No blower for heat nerdbit HVAC 5 09-20-2011 11:31 PM
Blower motor: Emerson to GE threeonesix HVAC 12 08-25-2011 04:59 PM
RUDD Blower Will Not Shut Off powerman02 HVAC 2 07-24-2011 05:59 AM
Bryant Furnace Blower Won't Shut Off aorozco HVAC 3 12-02-2010 02:20 AM
Trane Furnace Blower Running Nearly Continuously stephensandlin HVAC 3 01-03-2010 02:21 AM
