Furnace Blower Stays On - I Have Read A Bunch Of Posts - HVAC - DIY Chatroom Home Improvement Forum
Old 06-06-2011, 08:24 PM   #1
Furnace blower stays on - I have read a bunch of posts
I have a gas Rheem furnace model # 80pj07ear01 with central air. My a/c and heater work but my blower will not turn off with the thermostat set on AUTO.
I'm not sure where the blower relay is located to give it a whack or two, is it on the board posted below?
I have also read in anouther post that ''the crossover tubes on the burners were clogged'' which caused the same problem I am having. Not sure how to clean those if thats the problem.
Do I need to replace this?? I found the same model (62-24268-03) on amazon for $98 shipped.
bob barker is offline   Reply With Quote
Old 06-06-2011, 09:41 PM   #2
AKA HVACTECHFW
Rewards Points: 1,208
its on the board...... however, first check for 24V from G to C at the board.... this will tell you if it is t-stat or relay in control board.
IT IS WHAT IT IS
hvactech126 is offline   Reply With Quote
Old 06-06-2011, 10:00 PM   #3
Measured G to C and got ZERO, I dont know if that means my thermostat is bad or the relay
Old 06-06-2011, 10:09 PM   #4
AKA HVACTECHFW
it means that most likely the relay in the control board is stuck closed.
IT IS WHAT IT IS
Old 06-06-2011, 10:15 PM   #5
Which one would I tap, A?
Old 06-06-2011, 10:18 PM   #6
AKA HVACTECHFW
Hard to say, tap them all.......... Most likely it wont do anything......... Replace the board....
IT IS WHAT IT IS
Old 06-06-2011, 10:21 PM   #7
Thank you for your knowledge
Old 06-06-2011, 10:35 PM   #8
Missouri Bound's Avatar
www.hvacpartsoutlet.com if you plan on doing it yourself. Looks like yours is about $110. Check prices locally first and good luck
Last edited by Missouri Bound; 06-06-2011 at 10:41 PM. Reason: additional information
Old 06-07-2011, 04:29 AM   #9
An old Tradesmen
Rewards Points: 7,816
A. Should be the blower relay.
Old 06-11-2011, 02:00 PM   #10
**Update**
I ordered the board from a amazon seller for $100 and got it in 5-6 days. I just installed it and the unit works great
I checked with a local HVAc supply store and they wanted $225 for the board.
Old 06-11-2011, 08:44 PM   #11
Thanks for the update; glad you got it working.
Furnace blower only runs VERY slow... tippet HVAC 12 12-04-2010 04:50 PM
Rheem furnace blower problems ellioant HVAC 0 11-23-2009 11:38 PM
furnace blower zendarx2 HVAC 15 04-28-2009 10:56 AM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
Bryant Furnace Blower Running Constantly GhostBuster HVAC 15 11-30-2008 09:08 PM
