-   -   Furnace blower stays on - I have read a bunch of posts (http://www.diychatroom.com/f17/furnace-blower-stays-i-have-read-bunch-posts-106840/)
bob barker 06-06-2011 09:24 PM
I have a gas Rheem furnace model # 80pj07ear01 with central air. My a/c and heater work but my blower will not turn off with the thermostat set on AUTO.
I'm not sure where the blower relay is located to give it a whack or two, is it on the board posted below?
I have also read in anouther post that ''the crossover tubes on the burners were clogged'' which caused the same problem I am having. Not sure how to clean those if thats the problem.
http://i1081.photobucket.com/albums/...r/IMG_2019.jpg
http://i1081.photobucket.com/albums/...r/IMG_2020.jpg
Do I need to replace this?? I found the same model (62-24268-03) on amazon for $98 shipped.
http://i1081.photobucket.com/albums/...r/IMG_2021.jpg
hvactech126 06-06-2011 10:41 PM
its on the board...... however, first check for 24V from G to C at the board.... this will tell you if it is t-stat or relay in control board.
bob barker 06-06-2011 11:00 PM
Measured G to C and got ZERO, I dont know if that means my thermostat is bad or the relay :)
hvactech126 06-06-2011 11:09 PM
it means that most likely the relay in the control board is stuck closed.
bob barker 06-06-2011 11:15 PM
Which one would I tap, A?
http://i1081.photobucket.com/albums/...qwdklfcfkl.jpg
hvactech126 06-06-2011 11:18 PM
Hard to say, tap them all.......... Most likely it wont do anything......... Replace the board....
bob barker 06-06-2011 11:21 PM
Thank you for your knowledge
Missouri Bound 06-06-2011 11:35 PM
www.hvacpartsoutlet.com if you plan on doing it yourself. Looks like yours is about $110. Check prices locally first and good luck
beenthere 06-07-2011 05:29 AM
A. Should be the blower relay.
bob barker 06-11-2011 03:00 PM
**Update**
I ordered the board from a amazon seller for $100 and got it in 5-6 days. I just installed it and the unit works great :thumbup:
I checked with a local HVAc supply store and they wanted $225 for the board.
Missouri Bound 06-11-2011 09:44 PM
Thanks for the update; glad you got it working.
