Old 01-20-2013, 12:33 PM   #1
Furnace blower speed
where do I find furnace blower speed on a 75.000 80%
junoir is offline   Reply With Quote
Old 01-20-2013, 12:53 PM   #2
Experienced HVAC Tech
Need more info like model and serial number and brand. It may have a variable speed blower which is more complicated to change the speed on
HVAC1000 is offline   Reply With Quote
Old 01-20-2013, 12:56 PM   #3
how
You need to check the motor's designation to confirm which blower motor you have and which speed tap is currently being used.
how is offline   Reply With Quote
Old 01-20-2013, 01:13 PM   #4
How many wires come from it,vwhat color are they and where do they connect to the control board?
Old 01-20-2013, 02:04 PM   #5
Hvac Pro
wiring diagram
Old 01-21-2013, 11:15 AM   #6
Wiring diagram often on back of blower door panel. Multiple 'taps' are color coded wires that can be swapped to change speeds. Highest usually for A/C etc.
diyorpay is offline   Reply With Quote
Old 01-21-2013, 06:12 PM   #7
alot of blower speeds are found on control board...why do you ask...don't just change speed...will effect tempeture rise of furnace which can damage heat exchanger ...so why do you want to change speeds?????? ben sr
Strange oil furnace problem: blower comes on before burner robparrott HVAC 6 12-12-2011 02:55 PM
gas furnace whistling when on, not when blower on newguy2010 HVAC 0 12-03-2010 02:58 PM
Blower motor in old bryant furnace runs constantly GetYourShineBox HVAC 2 07-20-2010 08:49 PM
How much power does a small furnace blower use? Red Squirrel HVAC 10 07-31-2009 10:03 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
