Furnace Blower Speed - HVAC - DIY Chatroom Home Improvement Forum
Old 06-09-2012, 06:37 AM   #1
Furnace blower speed
How do i change the blower speed on an american standard furnace model # tus0808936ao?
KRT21654 is offline   Reply With Quote
Old 06-09-2012, 05:52 PM   #2
I can tell you that on my furnace there's a section that has many wires inside, with a cover. Included are wires with caps (connect to nothing).
Checking the schematic diagram on the back of the furnace door shows the motor with 4 different speeds depending on which wire is connected to the motor. To change the speed means disconnecting the current wire and substituting another. I believe my speeds were LOW, MED-Low, MED-high and HIGH.
Check for the diagram.
diyorpay is offline   Reply With Quote
Old 06-09-2012, 06:27 PM   #3
MarginallyQualified
Rewards Points: 2,464
And if the goal is limited to just two choices...
like say a slower speed for heat and faster speed for cooling?
this disconnect and substitute stuff can also be done using switches.
Old 06-09-2012, 09:08 PM   #4
Rewards Points: 582
why do you want too....heating needs to have enough air flow over heatexchanger for proper temp rise....cooling needs enough cfm across cooling coil so it does not freeze up...still need to change blower speed?????? ben
blower problems with bryant furnace. blowerissue HVAC 4 03-13-2012 11:34 PM
Strange oil furnace problem: blower comes on before burner robparrott HVAC 6 12-12-2011 01:55 PM
Carrier Weathermaker Gas Furnace - No blower for heat nerdbit HVAC 5 09-20-2011 10:31 PM
Blower motor in old bryant furnace runs constantly GetYourShineBox HVAC 2 07-20-2010 07:49 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
