Furnace Blower Short Cycling On AC Only - HVAC - DIY Chatroom Home Improvement Forum
Old 06-07-2011, 03:36 PM   #1
Furnace blower short cycling on AC only
I have a Armstrong gas forced air furnace and a Armstrong AC unit, not sure of the model numbers. Anyway, the fan short cycles when the AC is on. I tried it with the heat and it runs fine. It will bring the temperature down in the house it just takes longer to do so. I am hoping this is just a thermostat problem, I just replaced the filter also. the short cycling differs, sometimes it runs for 30 seconds and then shuts down for 15 seconds and repeats,other times it will run for maybe 3 - 4 minutes and then shuts down for 15 seconds and repeats. Any help would be GREATLY appreciated!
jaycamp is offline   Reply With Quote
Old 06-07-2011, 07:11 PM   #2
Rewards Points: 6,652
Need to post the model #s of both the furnace and the outside ac unit, and the tonnage of the outdoor unit if you have it. How many square feet is your house, and at what temp are you trying to set the thermostat at.
Old 06-07-2011, 10:06 PM   #3
I'm Your Huckleberry
Rewards Points: 2,270
Blower motor is going out.
Doc Holliday is offline   Reply With Quote
Furnace Blower Problem, help needed!!! lddnyp HVAC 4 01-15-2013 01:02 PM
Furnace blower only runs VERY slow... tippet HVAC 12 12-04-2010 04:50 PM
gas furnace whistling when on, not when blower on newguy2010 HVAC 0 12-03-2010 01:58 PM
Luxaire furnace blower will not shut off danaugstin HVAC 1 10-06-2009 09:14 PM
Furnace short cycling stubborn1 HVAC 2 12-08-2008 11:46 AM
