Furnace Blower Not Working On Heat Mode - HVAC - DIY Chatroom Home Improvement Forum
Old 10-25-2011, 07:41 PM   #1
Furnace blower not working on heat mode
I have a furnace blower motor that isn't working on the auto heat mode, it runs in the cooling mode or fan only, and if i start the fan on fan only and then switch to heat the motor keeps running, but when it shuts off and trys to come back on it just makes a loud humming noise and the fan turns very slowly
Sixshot is offline   Reply With Quote
Old 10-26-2011, 09:02 AM   #2
biggles's Avatar
when you switch to FAN/ON at the stat that is the HI speed of the supply motor for cooling,then when your calling heat the motor runs either LO or Med LO depending on brand.your LO motor winding is shot with the slow mo during heat...shut the furnace off and see if you have a Med LO wire or Medium to change from LO the speeds are colors check it out till you can change it...or just run the heat with fan in on from the stat
Help with furnace blower problem Spydey HVAC 6 12-15-2010 09:18 PM
Carrier Infinity 69 Trouble Code 42 bodya1 HVAC 4 12-05-2010 07:43 PM
Bizarre Heat Pump and Blower Behavior gatorinsc HVAC 3 01-11-2010 04:32 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
Furnace stops working once a day - help Da_Bears HVAC 2 01-26-2006 02:19 PM
