Furnace Blower Motor PLEASE HELP - HVAC - Page 2 - DIY Chatroom Home Improvement Forum
Old 01-04-2010, 09:45 AM   #16
An old Tradesmen
Rewards Points: 7,746
Disconnect the wires from the board, and remove entire housing from furnace.
Remove insert plates, Pull blower motor, off of wheel.
Install new whell, make sure its facing the right direction.
And reverse disassembly steps.
Old 01-04-2010, 09:50 AM   #17
Thanks for everything, really appreciate it
Paelectrican is offline   Reply With Quote
Old 01-04-2010, 12:12 PM   #18
Insert plates is where i'm caught up, did you mean the parts of the wheel?
Old 01-04-2010, 12:22 PM   #19
Yup, scrambled blower wheel. You say parts are warrantied. I would leave the repair to your HVAC contractor.
SKIP4661 is offline   Reply With Quote
Old 01-04-2010, 12:25 PM   #20
Thanks alrighty got it apart, my only question is how i get the new wheel on?
Old 01-04-2010, 12:26 PM   #21
Does the one side ride on the end plate?
Old 01-04-2010, 12:51 PM   #22
You need to loosen the set screw in the wheel hub. Remove the bolts that hold the motor in. Hopefully the wheel and housing slide free from the motor assembly. If not hold the shaft and spin the hub to loosen it. Remove the baffle plate from the top of the blower housing. Remove the old wheel and reverse the process. DO NOT scar up the blower motor shaft or put the wheel on backwards.
Old 01-04-2010, 01:05 PM   #23
Baffle? Working on getting hub off now, not having much luck turning the set screw
Old 01-04-2010, 01:35 PM   #24
Furnace blower motor PLEASE HELP-img00238-2-.jpgThis is where im at!
Old 01-04-2010, 05:31 PM   #25
An old Tradesmen
Did you get it yet.
The set screw shouldn't be that hard to turn from that point.
Old 01-04-2010, 05:34 PM   #26
Did you get it yet.
Got the set screw out, however i can not get the wheel part off the shaft. I get it to where it's flush coming out but can't get past there. Any advice?
Old 01-04-2010, 05:45 PM   #27
An old Tradesmen
Push the hub back to where it moves easier.
Then sand the shaft where it moves hard. then put a little oil on it. Should come off easy then.
Unless someone used a hammer on it.
Old 01-04-2010, 05:47 PM   #28
No hammer will have to try that thanks, hoping to get done tonight as it is very cold here, lol
Old 01-04-2010, 05:48 PM   #29
If i had to buy a motor for it, do you know around how much it would run?
Old 01-04-2010, 05:52 PM   #30
An old Tradesmen
I get mine from HVAC wholesale houses.
Don't know what one would charge you.
Trane Furnace Blower Running Nearly Continuously stephensandlin HVAC 3 01-03-2010 01:21 AM
Bryant Gas Furnace - blower sarts and stops montepix HVAC 7 12-24-2009 04:11 PM
How much power does a small furnace blower use? Red Squirrel HVAC 10 07-31-2009 09:03 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
Bryant Furnace Blower Running Constantly GhostBuster HVAC 15 11-30-2008 09:08 PM
