Furnace Blower Motor PLEASE HELP - HVAC - DIY Chatroom Home Improvement Forum
Old 01-04-2010, 07:59 AM   #1
Furnace blower motor PLEASE HELP
I was out of town for a couple days, i came home to hear weird noise from furnace. It appears my fan has loosened and is brushing against the housing. Is there an easy solution? Have pics of furnace and housing if it would help!
Paelectrican is offline   Reply With Quote
Old 01-04-2010, 08:10 AM   #2
Here is pic of furnace. Little over a year old!
Old 01-04-2010, 08:45 AM   #3
An old Tradesmen
Rewards Points: 7,794
Set screw probably came loose.
Turn power off to furnace.
Reach hand in blower wheel on left side. Feel around hub. You will find a set screw. Probably loose. Move blower wheel back to center on housing. align set screw with flat spot on shaft. Tighten screw.
You should check to make sure that motor shaft isn't rounded.
Old 01-04-2010, 08:52 AM   #4
Thanks i just talk to the company and my parts are still under warrenty, question i have is the blower wheel come with the blower motor or is that a separate part?
Old 01-04-2010, 08:57 AM   #5
An old Tradesmen
Separate part.
Blower wheel set screw coming loose is not covered under part warranty.
if its less then a year old. It is covered under installer labor warranty.
If more then a year old. Its a chargeable service call.
Old 01-04-2010, 08:59 AM   #6
Thanks how would i get the housing out to check everything?
Old 01-04-2010, 09:01 AM   #7
An old Tradesmen
You don't need to pull the housing.
There is enough room to put your hand in and check(barely).
Make sure power is OFF!
Old 01-04-2010, 09:04 AM   #8
Did but it feels like the whole wheel is just off completely! the set screw seems fine as well as motor
Old 01-04-2010, 09:08 AM   #9
An old Tradesmen
If by off. You mean off center.
Screw may or may not wiggle. It may have just left the wheel slide 1/4 to 1/2 inch.
Old 01-04-2010, 09:17 AM   #10
Will send pic! Is completely off
Furnace blower motor PLEASE HELP-_device-memory_home_user_pictures_img00232.jpg
Old 01-04-2010, 09:19 AM   #11
Furnace blower motor PLEASE HELP-_device-memory_home_user_pictures_img00237.jpg
Old 01-04-2010, 09:31 AM   #12
An old Tradesmen
Ok.
Yep. Blower wheel needs replaced.
Wheel probably under warranty if less then 5 years old. Labor isn't, if its more then a year old.
Old 01-04-2010, 09:33 AM   #13
Ok.
Is this something i can replace on my own?
Old 01-04-2010, 09:36 AM   #14
An old Tradesmen
Yeah.
Its not a fun thing. But not too hard. As long as you don't mix up the wires of the control board. During re-install of it.
Old 01-04-2010, 09:39 AM   #15
Yeah.
OK do i need to drop the housing?
Trane Furnace Blower Running Nearly Continuously stephensandlin HVAC 3 01-03-2010 01:21 AM
Bryant Gas Furnace - blower sarts and stops montepix HVAC 7 12-24-2009 04:11 PM
How much power does a small furnace blower use? Red Squirrel HVAC 10 07-31-2009 09:03 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
Bryant Furnace Blower Running Constantly GhostBuster HVAC 15 11-30-2008 09:08 PM
