Furnace Blower Motor Late - HVAC - DIY Chatroom Home Improvement Forum
Old 12-30-2011, 01:35 PM   #1
furnace blower motor late
I have an old Janitrol furnace. It runs, shuts off, then takes 20-30 seconds before the blower fan clicks on. I leveled the thermostat & that corrected the problem. The first time the temp was adjusted later, it threw it off again. Do I just need a new thermostat?
mmm76 is offline   Reply With Quote
Old 12-30-2011, 01:50 PM   #2
biggles's Avatar
if the stat has a mercury bulb it has to be level and tight can't move when you touch it....the fan cycle is thru the furnace heating not the stat...down on the furnace do you have a control mounted above the burners with number dial or temps stamped on it....set to 130F-150F that is your fan ON when the furnace heats up
The Following User Says Thank You to biggles For This Useful Post:
mmm76 (12-31-2011)
Old 12-30-2011, 02:30 PM   #3
how
Rewards Points: 1,104
If its an old janitrol, those controls are behind a metal cover. The cover gets unscrewed and pinched off but you have to turn the power off to the furnace first. That cover is insanely dangerous to remove when the furnace is live because of the protruding 120 V fan connections just inside of it.
The fan control needs to be adjusted down to a lower "ON" temp but too low will just have your fan running continuously.
how is offline   Reply With Quote
The Following 2 Users Say Thank You to how For This Useful Post:
ben's plumbing (12-30-2011), mmm76 (12-31-2011)
Old 12-30-2011, 02:34 PM   #4
Rewards Points: 582
maybe its me just what is your problem with furnace...
Old 12-30-2011, 03:04 PM   #5
how
No Ben, You might be right.
If his burners are turning off while the thermostat is actively calling for heat then the furnace has been limiting. In an older janitrol that is often because the blower was supposed to have come on much earlier.
If his burners are turning off because of overly active anticipation on an old thermostat, or the thermostat is just loose on the wall then the furnace maybe fine.
The Following User Says Thank You to how For This Useful Post:
furnace blower cover whistling BlueBSH HVAC 4 02-17-2011 03:09 PM
How much power does a small furnace blower use? Red Squirrel HVAC 10 07-31-2009 09:03 PM
Need Suggestions for Furnace Blower Assembly LordX HVAC 10 02-25-2009 06:06 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
furnace blower keeps running dmbrasket@hotmail.com HVAC 7 02-03-2008 03:57 PM
