Furnace Blower Motor Keeps Burning Up - HVAC - DIY Chatroom Home Improvement Forum
Old 08-22-2012, 06:11 PM   #1
Question
This began last Thursday (while I was out of town) after my wife turned the t-stat up. We are now on our 4th motor and have a stumped AC tech. Motor, fan relay, capacitor, and t-stats have all been replaced. Coils have been taken out and cleaned. The AC works fine and dandy once it's repaired but as soon as someone turns the thermostat up, the motor pops and emits a burned electrical smell. I would appreciate any suggestions you guys have as to what is causing the issue. I am ignorant to HVAC systems and also anything electrical...so keep it simple for me. Thanks!
cazejr is offline   Reply With Quote
Old 08-22-2012, 06:41 PM   #2
Rewards Points: 616
first off when in cooling mode turning a stat up does nothing..... turning it down starts the A/C ...does your blower motor run on low speed all the time....
carmon is offline   Reply With Quote
Old 08-22-2012, 06:49 PM   #3
No, it didn't run all the time...only when triggered by t-stat setting. Just fyi, we keep the t-stat set on a higher temp during the day while we are away and turn it back down when we get home. The motor burns up only after we turn the t-stat up.
Old 08-22-2012, 07:26 PM   #4
HOTDAWG
I would check your power supply
Affordable Comfort, assisting with furnaces Barrie and surrounding area, as well as offering 24 hour furnace repair
Acomfort is offline   Reply With Quote
Old 08-22-2012, 08:18 PM   #5
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Check your neutral wire going to furnace/blower motor.
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Old 08-22-2012, 08:19 PM   #6
Missouri Bound's Avatar
Is this a heat pump? You have a serious control issue supplying the motor with the wrong voltage....or you have installed a motor(s) of the wrong voltage.
Do you want it your way or the right way?
Old 08-22-2012, 08:21 PM   #7
An old Tradesmen
Rewards Points: 8,170
Sounds like the replacement motor got wired in wrong.
The Following User Says Thank You to beenthere For This Useful Post:
Missouri Bound (08-22-2012)
Bryant 355MAV furnace and A/C blower not starting rajar2 HVAC 39 11-05-2015 01:03 PM
blower problems with bryant furnace. blowerissue HVAC 4 03-13-2012 11:34 PM
Quote for new furnace. Reasonable? dengle HVAC 16 03-04-2012 07:01 AM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Payne gas furnace - blower fan running continuously Ed40 HVAC 0 02-05-2011 02:19 PM
