Furnace Blower Motor - HVAC - DIY Chatroom Home Improvement Forum
Old 05-02-2011, 05:45 PM   #1
furnace blower motor
hello, my blower will not run automatically on my furnace. the a/c unit runs outside and the fan will run, but not on auto. help
velva clayton is offline   Reply With Quote
Old 05-02-2011, 11:55 PM   #2
Registered User
Rewards Points: 5,256
Welcome to the forum!
I moved you to "HVAC" for better response...
Gary
Old 05-03-2011, 01:01 AM   #3
So to clarify, the blower will run only if the thermostat has the blower set to "on" and not when it's set to "auto"?
The problem is either the thermostat, the thermostat wiring, or the furnace controller.
What I would do is disconnect the thermostat, in case it's doing something strange, and jumper the Yellow to the Red wire (24V RC to Cooling Call). If the system operates normally in this mode, then it's the thermostat. If not, then the furnace controller board is not working properly.
If yours is a more complicated system, like a heat pump, then there will be more wires and the wire colors may be different.
Be sure you understand what wires do what, turn off the furnace breaker first, since 24V hurts a fair amount, and you could wipe out the furnace controller if you shorted it. If you are not comfortable working with this sort of thing, then a service call to a HVAC pro would get it fixed very quickly.
http://wiki.xtronics.com/index.php/T...8G.29_terminal
Robo_geek is offline   Reply With Quote
Blower Motor Wiring Help atvguy64 Electrical 11 08-14-2015 10:02 PM
Blower problem on American Standard Freedom 90 furnace ekimmo HVAC 8 08-27-2011 10:13 PM
Blower Motor in Carrier WeatherMaker 58MVP080 pbong HVAC 0 10-06-2009 09:08 PM
Trouble shooting a Blower Motor cougar HVAC 10 07-15-2008 09:14 AM
Replace a furnace blower motor dadncharge HVAC 2 12-06-2007 10:42 PM
