Old 10-01-2012, 05:31 PM   #1
furnace blower continually runs
how to find out how to stop it and fix the problem
Glorysquestion is offline   Reply With Quote
Old 10-01-2012, 05:45 PM   #2
need more than that....make model would help....is fan switch on thermostat set to on....
Old 10-01-2012, 06:57 PM   #3
An old Tradesmen
Could be a stuck high limit. Could be a low voltage short. Could be the fan switch on the stat is set to on. Could be the fan switch on the fan limit switch is set to on. Could be the fan relay on a control board is stuck/burnt close. Could be a bad control board. Those are off the top of my head.
What did you check so far.
Old 10-01-2012, 06:59 PM   #4
well were done with this guessing game you named most if not all i was being kind not to overwhelm op...
Old 10-01-2012, 07:08 PM   #5
An old Tradesmen
I was trying to cover most of the bases. The question is a bit vague, so I ended up using a broad answer.
The Following User Says Thank You to beenthere For This Useful Post:
ben's plumbing (10-01-2012)
Replace furnace or blower agibby5 HVAC 6 07-17-2012 07:17 PM
Gas furnace blower AC retrofit problem agibby5 HVAC 0 07-09-2012 07:58 PM
Blower fan continually runs after heat has stoped Bob Stein Appliances 6 11-11-2011 04:06 PM
Carrier Weathermaker Gas Furnace - No blower for heat nerdbit HVAC 5 09-20-2011 11:31 PM
Bryant Gas Furnace - blower sarts and stops montepix HVAC 7 12-24-2009 05:11 PM
