Old 01-02-2008, 09:18 PM   #1
furnace and basement size
im buying a gas furnace to install forced hot air in my house and i am getting the combo with ac condenser and coil. my house is a 1920s colonial and the basement is only 82 inches high to the bottom of the studs. my furnace is 40 inches high and the cased coil is 30 inches leaving only 12 inches for plenum . do you guys think thats too little of is that fine enough to just use the takeoff . would it be better to get the uncased coil and maybe i would hvae more room for the plenum or do i need the same type of clearance with the uncased coil? thanks guys
qnzkrew is offline   Reply With Quote
Old 01-02-2008, 11:40 PM   #2
Union HVAC Tech.
Put in a horizontal furnace and give yourself some room.
bigMikeB is offline   Reply With Quote
More On This Topic
Hi, I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. One thing to remember when plumbing your basement, is that the location of the toilet is not as important as it first may seem. Where that pipe is sticking... Read More »
Hi, I'm Jeremy Blackwell, I'm here today to help you get started on your basement remodel project. Something else you want to think about if you do decide to finish your basement in stages, is access to the plumbing and heating. If you decide to finish... Read More »
Hi! This is Jon on behalf of Expert Village. In this video clip I will be showing you how to check your furnace filter. The first thing you need to do is locate your furnace. Now in many houses, the furnace is located in the laundry room which is in the... Read More »
Hi, I'm Nipa Banerjee from Arts Space India I'm talking on behalf of Expert Village. This is the furnace and this is the door of the furnace, see these are ceramic tiles, this is fiber and these there is 2 coils inside the furnace. After finishing up the... Read More »
Newer, more energy efficient homes have been constructed to seal out the outdoor environment almost 100 percent. This condition allows loaded, stale air to accumulate unless windows are opened. Open windows allow some of the heating or air conditioning... Read More »
Moving Furnace to end of basement tigerbalm2424 HVAC 10 01-07-2010 09:27 AM
Furnace Exhaust To Outdoors celticFC HVAC 1 09-01-2007 02:27 PM
Furnace & Building Guidelines... peppie35 HVAC 5 03-17-2007 03:14 PM
Could installing a furnace to the floor joists cause the floor to slope? JKL HVAC 5 01-03-2007 10:23 PM
Gas furnace exhaust vent question nowell HVAC 1 03-13-2005 12:49 PM
Copyright ©2000 - 2010, Jelsoft Enterprises Ltd.
