Furnace On Basement Floor - HVAC - DIY Chatroom Home Improvement Forum
Old 03-18-2009, 01:50 PM   #1
Furnace on Basement floor
Is it allowable to place a standard upflow gas furnace directly on a concrete basement floor or does it have to be raised up off the floor. I am located in New Jersey.
Carl.
carlb23 is offline   Reply With Quote
Old 03-18-2009, 01:55 PM   #2
An old Tradesmen
Rewards Points: 8,176
It can be done.
But, its better to have it off the floor.
Old 03-18-2009, 02:05 PM   #3
That's what I thought but even with it on the floor, the furnace, a/c coil and the plenum puts the clearance between the top of the plenum and the bottom of the floor joists is only 2.5" so i guess it will be on the floor.
Carl
Old 03-18-2009, 03:52 PM   #4
Hvac Pro
yuri's Avatar
Rewards Points: 392
Check the rating inside the furnace and call your gas authority. May only need 1" clearance at the top to combustibles. Unless the floor can get wet there is no problem with putting it directly on it.
Seal Peel and Stick Tiles? Echo1 Flooring 21 06-22-2012 09:07 PM
Removed basement stairs - put in floor for washer and dryer capslock Flooring 3 10-09-2010 02:15 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
Need Help! Wet basement floor??? JamoDenver Building & Construction 5 01-11-2008 11:43 AM
