Furnace, Auto Fan Not Working - HVAC - DIY Chatroom Home Improvement Forum
Old 10-01-2011, 07:11 PM   #1
furnace, auto fan not working
the burner comes on but the auto fan won't come on
we can turn on the fan manual and that works OK
the fan works fine on air conditioner auto
Ken A. is offline   Reply With Quote
Old 10-01-2011, 07:17 PM   #2
JJboy's Avatar
probably your flame sensor is dirty or has ground problem.
**Always kill the power ** Hot air rises, but heat will always move from higher to lower temperatures. ** Real man shoot in manual. ** If it ain't grounded, it ain't dead.
JJboy is offline   Reply With Quote
Old 10-01-2011, 07:29 PM   #3
Rewards Points: 484
He says the burner is running. Probably has a bad fan/limit switch.
sammy37 is offline   Reply With Quote
Old 10-01-2011, 08:02 PM   #4
JJboy's Avatar
I know, but he also says the blower motor is working in cooling mode and auto.
Old 10-01-2011, 08:27 PM   #5
HVAC Tech/ Browns Fan
It can be a fan relay switch or limit. If it has control board then it a relay on the board. You be able take board of bracket and see if burn up on backside .
Tator1076 is offline   Reply With Quote
Old 10-01-2011, 08:28 PM   #6
HvacWiz's Avatar
Rewards Points: 252
Depending on what type of furnace it is, Its either the fan limit switch or the circuit board.
HvacWiz is offline   Reply With Quote
Old 10-01-2011, 08:55 PM   #7
I'm Your Huckleberry
Rewards Points: 2,270
I don't even understand the problem.
Doc Holliday is offline   Reply With Quote
Old 10-01-2011, 08:55 PM   #8
Rewards Points: 484
He says if he puts the fan from auto to on that it works. It also works in cooling mode but it wont turn on in heat, that tells me that the fan/limit switch which is seperate from the fan relay, which controls the cooling and fan on, is bad.
I recently worked an old Carrier gas pack with the same issue and instead of fixing the bad part, the last tech on the job set the back of the thermostat from gas to electric, that way in heating mode it was relying on the fan relay. This is bad though because the heat exchanger doesnt get to cool down after the call for heating is over, just instant stop.
I had to replace the fan/limit switch in that and all was well.
And like the others said, if the unit has a board, that could be bad also.
Old 10-02-2011, 12:22 AM   #9
JJboy's Avatar
I agree, but I want to see if OP will tell us if burner stay on for a couple minutes or turn on/off quickly
RUUD Furnace Fan Won't Run on 'Auto' eggerldave HVAC 5 07-11-2011 10:21 AM
Where to donte a working furnace? vkaura HVAC 2 12-25-2010 07:58 PM
Furnace is working but no heat Lon1974 HVAC 21 09-12-2010 10:00 PM
RUUD furnace not working blower runs ddeatrick99@hotmail.com HVAC 2 01-16-2008 09:55 PM
Furnace not working right TheBillman HVAC 2 11-20-2005 05:31 PM
