Furnace Air Intake Noise - HVAC - DIY Chatroom Home Improvement Forum
Old 02-23-2010, 03:58 PM   #1
I have a single central air intake vent for the furnace (Goodman GMP050-3) which supplies my two-story townhouse. Unfortunately, this intake vent is located in my living room. Whenever the heater or AC is active, it sounds like a jet engine in the room. As per the pictures below, the furnace is only ~12" from the vent itself. Air intake comes via a 14x18" hole connected to the furnace by a metal duct. The hole is then covered by two 15x30x1 filters, and covered by a 30x30" grill.
As far as I can tell, the noise is entirely air flow - i.e. there does not seem to be any problem with vibration.
I am looking for any way to reduce the noise without too dearly compromising the system. I would also, for cost reasons, like to first try methods that did not involve the addition of new vents. Given that there is only a single 12" duct currently, I imagine there is little room for a bend of any sort. I was wondering if any sort of baffle might be appropriate.
Also, as the filters are in need of change - would any specific types of filters help with noise reduction.
I am sure it is evident that I do not really understand much of what I am asking about. I would appreciate any thoughts. Thanks.
monkeywoods is offline   Reply With Quote
Old 02-23-2010, 05:26 PM   #2
Rewards Points: 159
Take the return grille off and see how much that reduces the noise. I had a similar problem at a friends house and I clipped out every other louvre in the return grille and that reduced the noise significantly.
kb3ca is offline   Reply With Quote
Tags
duct , furnace , hvac air intake furnace , noise , vent
Brand new Coleman 97.5% furnace makes horrible whining noise junebuggy HVAC 10 11-15-2016 10:53 AM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 04:51 PM
Noisy furnace (with recording of noise) Jeffrey HVAC 3 01-23-2010 02:17 PM
Furnace intake noise question joeg679 HVAC 6 12-11-2009 01:03 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 02:55 PM
