Furnace And Air Condition Sizes - HVAC - DIY Chatroom Home Improvement Forum
Old 11-18-2010, 09:08 PM   #1
Furnace and Air Condition Sizes
We have had 3 different estimates to replace our HVAC systems. The recommended sizes on the furnace range from 60,000 BTUs to 90,000 BTUs at 95% efficiency. The A/C range from a 2.5 ton to a 3 ton.
Our home is about 2000 square feet and we live in SW Ohio.
How do we know which is right?
akaponte is offline   Reply With Quote
Old 11-19-2010, 03:14 AM   #2
An old Tradesmen
Rewards Points: 7,816
May want to do your own load calc.
http://hvaccomputer.com/talkref.asp
A 90,000 95% furnace needs to move a lot of air. So you don't want to get a furnace that is oversized for your ducts, and sounds like a jet engine while running. Let alone uses more gas then needed.
Same problem can happen with the A/C. Too large uses more electric, and can require to much air flow through the duct work.
