-   -   furnace acting funny (http://www.diychatroom.com/f17/furnace-acting-funny-172304/)
davidnewyork 02-18-2013 04:53 PM
hi,
I have a payne plus90 gas furnace. The furnace seems to go through its cylce properly, flames lite and stay on but the house doesnt warm up. I can feel air coming through all the registers. Has anyone encountered a issue like this. Any help on this would be greatly appreciated. Thank you.
how 02-18-2013 05:18 PM
Do the flames stay on as long as the thermostat is calling for heat?
I assume the flames are never shutting off because the house is not heating up?
Do you have a two stage gas valve that is staying on the low fire position?
davidnewyork 02-18-2013 05:27 PM
hi
yes the flames do stay on, but i'm not sure what a 2 stage gas valve is though. the furnace was working fine this winter then about 2 weeks ago i had to replace a smaller fan located near the burners. it seemed to work ok after that, but then yesterday the thermostat was set at 70 but was showing 64, then last night it kept dropping until it reach 60, but all the while the flames and fan were running.
av-geek 02-18-2013 08:01 PM
Many gas furnaces can operate in low or high fire modes. If you unit is firing only in low, it's probably not producing enough heat to maintain temperature in your home. This would most likely be a thermostat problem because the thermostat should engage the high-fire rate once the temperature drops too far below the set point. WHen the furnace switches to high-fire mode, it should also speed up the draft fan. That is the fan that I am assuming you replaced that you described as "a small fan near the burners". It basically sucks the burnt exhaust out the heat exchangers and blows them outside (and also sucks fresh air through the heat exchangers in at the burners where it mixes with the gas to be burned) I am thinking that maybe a single speed blower was installed in the furnace, and you have a 2-speed furnace, so without the extra speed on the draft fan, the burner is not going into high-fire mode to make up the difference on the really cold night.
Are you actually getting warm air out the furnace? After it's been running for a while, put your hand at a duct and feel if you've actually got warm air coming in. A likely scenario is that a piece of ductwork may have come loose and is leaking. If the supply duct came loose, some or all of your warm air is blowing out into the unconditioned attic or crawl space. If the return air duct has come loose, chances are, the air coming out will not be as warm as it should (because the furnace is sucking cold air from outside, instead of inside) and the furnace is actually pressurizing your house, and forcing the conditioned air out at all the cracks and crevices. You should be able to tell this if you open an outside door slightly and you feel a wind blowing out the house.
davidnewyork 02-19-2013 08:04 AM
thank you
thank you for your replies so far. i closed up some air leaks i found in the duct work and last night the house was set at 70 and stayed at 70. What is happening now though is the furnace keeps running even though the thermostat reads room temp of 70 but only during the late hrs of the night. the rest of the time it seems to work just fine. Could this be because the attic gets so cold at night?
