Furnace AC Drain Mess - HVAC - DIY Chatroom Home Improvement Forum
Old 02-01-2014, 07:43 PM   #1
Rewards Points: 12
Furnace AC drain mess
Hi there. Does anyone have any suggestions to clean up this mess. The picture shows the drain lines for my furnace, ac, and humidifier. The floor drain cover is rusty and corroded, the lines are dirty and not draped well and it just looks ugly.
I moved into this house 5 months ago and just getting to this.
Thanks in advance for any useful suggestions.
montydog is offline   Reply With Quote
Old 02-02-2014, 07:28 AM   #2
MarginallyQualified
Rewards Points: 2,464
Does anyone have any suggestions to clean up this mess?
Rip it all out and start over.
The Following User Says Thank You to TarheelTerp For This Useful Post:
plummen (02-02-2014)
Old 02-02-2014, 09:23 AM   #3
Rewards Points: 12
Thanks. I was thinking of just replacing the tubing and getting a new floor drain grate. Is there a better way?
Old 02-02-2014, 09:53 AM   #4
Rewards Points: 5,974
Some where back say against the wall tie all 3 into 1 drain line run it over to the drain put an elbow on it. Notch your cover for the line, put a short nipple on the elbow so it drains below the cover.
Old 02-02-2014, 11:45 AM   #5
An old Tradesmen
Rewards Points: 7,356
Moved to HVAC forum.
Old 02-02-2014, 12:08 PM   #6
Hvac Pro
yuri's Avatar
Rewards Points: 2,260
they all look like that. there are plastic grates nowadays. throw some CLR on it and rinse it if you want.
Old 02-02-2014, 12:19 PM   #7
retired elect/hvac/plumb
plummen's Avatar
Location: south east of omaha/The island of misfit contractors
Rewards Points: 2,020
Running it down inside the drain cover wont fly in a lot of places.
"facts" have no relevance to this discusion
Posting from a concrete bunker under a non descript barn
plummen is offline   Reply With Quote
Nordyne furnace, error code: Pressure switch stuck closed. javagrendel HVAC 22 04-25-2017 03:02 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
slope of ac drain and condensing furnace drain. hartkem HVAC 5 11-24-2008 08:38 AM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
90% Furnace, AC Drain, & Secondary drain pan. Hook all together? hartkem HVAC 25 11-18-2008 12:34 AM
