Furnace - HVAC - DIY Chatroom Home Improvement Forum
Old 01-21-2011, 01:08 AM   #1
Furnace
Have Lennox furnace two stage system. Had heating and ac service in to check on furnace problem. Discovered that pressure switch hose filled with water not allowing burners to stay on. Guy drain the hose but still filling with water, was told it was condensation, water should drain through the PVC drain pipe leading to drain. Why is so much water building up and getting in hose of pressure switch?
Trooper is offline   Reply With Quote
Old 01-21-2011, 08:20 AM   #2
Rewards Points: 5,332
Did he check to see if the condensate path wasn't clogged? Water will find a secondary path if the primary one is blocked.
When the service guy was there, any reason he didn't actually fix the issue?
Ron
Lennox Furnace G27M Series Unreliable operation: pressure switch or else? sheppard1977 HVAC 7 01-14-2013 05:42 PM
Water Inside/Around American Standard Furnace michrob HVAC 8 12-08-2011 03:51 PM
Furnace Model # Feh-015-04 clicking but not turning on? haimei HVAC 1 12-14-2010 05:01 PM
Problems with new furnace..Overheating, having to reset. Furnace too big? Tommy2 HVAC 41 12-01-2008 01:55 PM
New Cased Coil - Install to Furnace - PICTURES!! hartkem HVAC 39 11-18-2008 01:45 AM
